video chatroom
video chatroom
we got a web chatroom setup.
http://globalipvideo.com/page_room.php? ... erhandbook
will be setting up times for video conferences. still trying to figure out the audio end of it but its there.
Re: video chatroom
after our 2nd contact, when I tried to adjust the audio settings, I could not connect to you again. Perhaps you would outline the settings procedure when you have it working , and thanks. H.
Re: video chatroom
make sure that you have your speakers and microphone selected
the microphone level should be 100% and the boost should be +10.0
on the video chat screen go to config
then go to the microphone and set at half record volume. keep moving up just to you get echo and distortion
make sure you do not have two sets of speakers set up or do not listen to the microphone output through your speakers.
