new direction
new direction
I am moving my shop in new directions. I am moving from one-off design anything frames to a set production style. I will have the tire width built for a 140, 200, or 250. I will build a chopper frame 2, 4, or 6 up, 2 or 4 out. the prostreet style 0,2, or 4 up and 4 or 6 out. all the frames will have the same seat height oil tank motor mounts trans mount and battery location. I think i will only do hardtails. I will only do 35, 38, and 40* rake. I will be changing my frame jig over to a production setup with an adjustable neck setup and that is about it. Basically the jig will look something like this.
Re: new direction
Good business move! Is that the frame you are producing? I'ld like to know the story of the formed metal componants.
