NEED DA PART???
NEED DA PART???
Please tell me some one has a front 21 in harley rim 2.15 width and 3/4 axle with Mini Brake?
Or know a place to get a spoke one dirt cheap?
Having problems finding at good price?
Thanks!
Nathan
Thanks!
Nathan
Re: NEED DA PART???
Have you tried looking for older Jap Dirt Bike front Wheels?Not going to have a 3/4 axle,but I'm sure you could make shims if needed.
Re: NEED DA PART???
Need a mini front brake drum?
Has to be 21in too because bike set up for that wheel?
If I have to sheel out some cash well but need places to buy or some one got a friend?
Want a 21in 2.15 3/4 axle spoke mini brake front wheel?
Re: NEED DA PART???
It is going to get painted so does not have to be pretty?
Just not bent?
Just not bent?
Re: NEED DA PART???
So you're saying something like this isn't gonna work for you?
This is on E-Bay right now.It's off a 76Honda Trails Bike 21' Rim.Changing the shape of the Earth...1 bucket at a time...IUOE local 825 top of the food chain
Re: NEED DA PART???
I did not say it would not work?
I just do not know what else to look for and the stainless end covers are made 3/4 11 tpi so would have to remake them and make bushings for the axles in girder and remake axle?
I thought someone may know where to get the 21in harley rim used or a good suplier?
Give me link to that?
Re: NEED DA PART???
Well , If yer like me you aint gonna turn loose of a dime that you don't have to , but if all else fails and you can find a suitable hub you could always call buchanan fer the rim !(no I dont have the link but google will provide )
Re: NEED DA PART???
I had not planed on this but it will keep me from remaking my handle bars and will give me a front brake.
I can find them but they want so much cash for them and I am going to paint it so to buy a pretty crome on then paint it?
Re: NEED DA PART???
If yer saying what I think , no need to paint chrome as buchanan sells them without it as well !
Re: NEED DA PART???
This is the best I can find is it a 3/4 axle?
The 3/4 axle is a bitch to find!! 325$ for this one?
http://www.bikerparts-superstore.com/ti ... MgodtC8A0Q
Re: NEED DA PART???
you have a lathe, how come you don't turn one?
Re: NEED DA PART???
A Wheel hub with mini brake?
Need this have the axle
21" x 2.15" Mini Brake Wheel 40 Spoke for Harley & Customs
APPLICATION:
Custom application
DETAILS:
21" x 2.15" Chopper style wheel with a flat style rim, 3-1/2" wide hub, 40 chrome spokes. Brake cable and anchor bar are included. Wheel has a 5/8" and is a drum brake design
This spool wheel is laced and trued with 3/4" heavy duty bearings installed. Fits 1973 & later models with 3/4" axles. Wyatt Gatling & Paughco custom springers require axle kit, 3/4" inner diameter spacers and backing plate stay bar, sold separately. NOTE: All spokes on wheel need to be inspected and re-torqued after 500 miles of original installation.
UOM: EA
TECH NOTES:
Suggested to use #44-2016 Axle Kit.
Please Note: HD-OEM Parts are not made by Harley-Davidson. They have been manufactured to the same specifications as authentic Harley-Davidson OEM parts and should fit like original equipment manufacturer parts. The HD-OEM number is included for reference purposes only.
TAGS:
Model: 52-0358
Shipping Weight: 32lbs
Manufactured by: V-Twin Mfg
$342.36
Sale: $325.24
APPLICATION:
Custom application
DETAILS:
UOM: EA
TECH NOTES:
TAGS:
Model: 52-0358
$342.36
Sale: $325.24
Re: NEED DA PART???
Check your PM's
