Rear Wheel Offset?
Re: Rear Wheel Offset?
Post by Maz » Thu Jan 26, 2012 4:50 pm
Jeff L wrote:Is there room inside a Jap unit to space the front sprocket?I know there is no room on a Brit unit to do that.
there is generally only room for a very small spacer. When I did the GS550 for my sister I had to space the front sprocket out by almost half an inch (10mm) and the clutch actuating cable and lmechanism got in the way, so I made a spacer for the outer cover as well plus an extension for the clutch pushrod.....not difficult and still keeps the cover looking stock.... :banana-dance:
On my FZ750 project I have to space the front sprocket out by around 2 inches (50mm) so will need an outrigger bearing......... :think:
Nero
SELF INTRODUCTION: I'm an informatic engineer who just happened to leave his (relatively well paid) job to follow his passion and going to work at minimum wage as a CAD designer and a welder in a CNC laser cutting & general sheet metal fabrication shop.
In the meanwhile, I try to build a killer bike with whatever I have at hand...
Post by Nero » Thu Jan 26, 2012 6:47 pm
Whoa, 50mm it's a lot... wouldn't it be better to offset a little the engine also?
Will follow your build for sure... :mrgreen:
What I'm currently working at (and some free Italian's lessons also :D ) : http://costafabbricustomchoppers.blogspot.com/
Post by Jeff L » Thu Jan 26, 2012 10:21 pm
cool....thats good to know.Gives me more options when I ever get around to choppin my Honda.
Post by Maz » Fri Jan 27, 2012 3:15 pm
Jeff - I don't want to jack this thread but when I get the GS550 back for a couple of small mods and to re-laquer the cases, I'll take some pics of the spacers and stuff and post them....
