Front engined VW
Re: Front engined VW
FYI , I just remembered this springer build from a while back.
Check his rockers, they are not like yours, but very original.
http://www.chopperweb.info/forum/showth ... genumber=2
DeathBySnuSnu
SELF INTRODUCTION: A backwoods redneck from way down south.
Post by DeathBySnuSnu »
Well the little 11yr old girl took up dirt track oval racing. I have been heavy into being pit crew. So i have not been working on the scooter until recently.
She is getting competitive. On pace in the mix and getting good at driving sideways.
DeathBySnuSnu
Back to the scooter..
Getting a rechop and rebuild.
Engine is going 2387cc fuel injected and distributer less.
I have collected a pile of parts and pieces and started some machine work. A lonnnnnnnng way to go.
But the rockers ended up simple straight forward items.
Same geometry but no frills.
gasketscraper
SELF INTRODUCTION: Long time Member, but been out of touch for a while. Been building and riding since my early teens. I work in Alaska for half the year, reside in Seattle the other half. Turn wrenches, weld and fabricate for a living in the Commercial Marine Industry. Have 3 bikes under construction and several riders. Harleys, Nortons and an Indian scout. Enjoy the talent of the individuals on this site!
Post by gasketscraper »
Trike looks great! Now, let me be the dumb-ass (didn't see anyone else ask), what did you do to get 4 forward gears when the engine/ trans is "backwards" as opposed to a V W Beetle? What am I missing? Seems like you'd have 4 speeds in reverse!
On an older ( 74 0n back ) VW transaxle if you remove and swap side for side the covers that the half shafts go into the trans thru you will reverse the trans output ! The diff carrier and ring gear comes off as a unit with one of the covers and will fit either side !
gasketscraper
Thanks, Gearhead. Seem to recall that Buggy guys used a Bus trans-axle for lower gearing. But didn't know about the reversing option.
DeathBySnuSnu
Actually no.
But flipping the ring is the easiest way to do it.
I flipped the entire trans. Just took some internal machine work on the oiling. It made my engine be six inches lower than "normal would be.
DeathBySnuSnu
DeathBySnuSnu
DeathBySnuSnu
First mock up of the front end pieces the other day.
got it looking good.
If you flipped the trans, did you flip the engine also, make an adapter plate ...... ?
DeathBySnuSnu
Sorry about the long delay. I don't check this site very often.
I will get you some info up.
DeathBySnuSnu
The engine is not bolted to the upside down trans.
This empty case and adapter is between the engine and trans.
This moves the engine forward about 17 inches.
DeathBySnuSnu
