Two seater trike
- SELF INTRODUCTION: Just an Iowa country boy that has been pouring concrete for over 30 years. I have been around for awhile. I have watched 3 forums come and go. I built my first chop with the help of the great guys on this forum. I plan on building a few more. $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ I don't have the 200 word in me this morning! 8)
Re: Two seater trike
Thanks for the kind words Dan. It's been a long journey so far. Building a trike is quite a different animal compared to a bike. A lot of new things to think about.
I will do anything I can to try and help you with your wheels Dan. It will be hard to check anything without tearing the assembly all apart again........which sucks. You will be back at square one. I am guessing that Pete did the originals. How much did your piston change to make you decide to rebalance?
Just some mock up fun pics trying to decide some design paths..........
man that is some nice tube work there
I'm watching this one real close. Nice work.
Thanks guys and "YES" the tube work has been a little tedious.......8)
- SELF INTRODUCTION: Long time Member, but been out of touch for a while. Been building and riding since my early teens. I work in Alaska for half the year, reside in Seattle the other half. Turn wrenches, weld and fabricate for a living in the Commercial Marine Industry. Have 3 bikes under construction and several riders. Harleys, Nortons and an Indian scout. Enjoy the talent of the individuals on this site!
Scott as always, your talent and energy level never ceases to amaze me. This is going to be a righteous ride! Todd
- sleepyonthree
curt wrote:man that is some nice tube work there
I second Curt on that. In the raw as is its looking good.
Long time no see Todd! Thanks for your kind words guys.gasketscraper wrote:Scott as always, your talent and energy level never ceases to amaze me. This is going to be a righteous ride! Todd
I have the tubes 50% welded in. Now to work on making the oil tank
A little more done. Rear end is all welded up. I put a spare girder on it without cups or bearings for a fun mock up.
Scott, that just looks RIGHT in all aspects...
Very, very nice.
Very, very nice.
Thank You Bob.
My friend wanted this trike slammed with a drop seat. His butt will be around 3" above the chain and around 18-19" off the pavement. We both agreed that there would need to be two chain tensioners, top and bottom. This axle is approximately 16" back from the stock location.
We struggled for awhile about the oil tank. The wishbone tubes are slammed so low that a frame symmetrical oil tank was going to be a bitch. I went a different route and boxed in the frame with 16 ga. and I knew before I started it that the chain was going to cut into it. I was hoping I wouldn't have to put in another drain plug but it didn't work out that way. I got the chain frenched in today.
Marking out for cutting the spout in. Got that cut out. Just need to weld in the other drain plug and then I can clean out the tank and start fitting and welding the top of the tank.
Your trike has a great profile.
Nice fab work on the tank.
How are your clearances for the drain ; Edit...will it be tight to do an oil change?
Thanks Hans. Clearances for the the drain are good to go.
Scott, are there any updates on this project? Really like where this is headed.
