Page 8 of 11
Re: Front engined VW
Posted: Thu Oct 12, 2017 8:02 am
by DeathBySnuSnu
I had planned on re-creating this test yesterday evening.
But wanted to prime up the oil system first.
Which I did do and everything seemed to work as it should.
I had to turn down the regulator all the way to get to 30 psi.
But that pressure can is a bit more difficult to control than expected. I made a big mess right off the bat. Sprayed about a quart of oil all over the place including in my face.
So after the prime up and subsequent clean up I just went in to bathe the oil out of what's left of my hair.....lol
- 15067970159682.jpg (82.91 KiB) Viewed 6734 times
Posted: Thu Oct 12, 2017 11:21 am
by Dusty-Dave
That's a serious ass pre-oiler! I usually use a hand pumped brake bleeder and have manged to get pre-oiled a little but nothing like that.
Posted: Thu Oct 12, 2017 4:42 pm
by DeathBySnuSnu
Put all 5 quarts in through it.
I only takes a small shot of air to pressure up.
I put way too much air in on the first shot and pegged out the 100 psi gauges.
In a panic to get the pressure off before blowing the filters off I hit the air dump valve while looking directly at it.
Can had 5 quarts in it and I guess the oil galley had a good bit of air pressure pushing back as it was not Primed, I had just started.
So popped the air hose quick release and slapped open the air valve. Oil pushed back and I got a good pressure stream right back out the air hole.
Live and learn.
I had just made this out of whatever I had laying around.
Had to learn how to use it somehow.
Posted: Fri Oct 13, 2017 9:32 pm
by DeathBySnuSnu
Okey dokey then.......
As there are no questions then let me ask one.
So the throttle bodies came off a kwak zx12r.
It was a speed density system.
I have programmed up Alpha N.
I am lead to believe that I won't have enough vacuum span to actually use the MAP.
So I made a vacuum accumulator can today.
Hoping I can get some speed density going on.
It would improve drivability.
So whatcha think?
Will the fk10 (270 @ .050) cam make enough vacuum span to program with?
- 15079406012770.jpg (89.22 KiB) Viewed 6718 times
Posted: Sat Oct 14, 2017 3:47 pm
by DeathBySnuSnu
Half a header welded and ready.
- 15080089757410.jpg (131.02 KiB) Viewed 6712 times
Posted: Sun Oct 15, 2017 11:21 am
by DeathBySnuSnu
Exhaust pipe goes in here.....right?
- 15080807538041.jpg (98.48 KiB) Viewed 6705 times
Posted: Sun Oct 15, 2017 11:24 am
by DeathBySnuSnu
And out the other side.
- 15080807721552.jpg (113.92 KiB) Viewed 6705 times
- 15080807903953.jpg (122.41 KiB) Viewed 6705 times
Posted: Sun Oct 15, 2017 11:25 am
by DeathBySnuSnu
Now to weld up the other header.
- 15080808191194.jpg (81.01 KiB) Viewed 6705 times
Posted: Mon Oct 16, 2017 8:49 pm
by DeathBySnuSnu
Curing time has ended.
Now doing the P4G test on the por15.
- 15082007590860.jpg (70.98 KiB) Viewed 6699 times
Posted: Tue Oct 17, 2017 7:47 pm
by DeathBySnuSnu
I am at 24hrs in the gas that is considered to be the worse here.
It is not even colored the same as the others.
Zero effect on the pot 15.
I suppose another 24 hrs in the gas I commonly run wouldn't hurt.
Posted: Thu Oct 19, 2017 8:11 pm
by DeathBySnuSnu
So.
24 hrs in the cheap gas.
24hrs in the gas at the corner .
24hrs in the good gas across town.
And zilch.
No effect.
Of course there is no telling what there will be in gas in the future.
Posted: Sat Oct 21, 2017 1:55 pm
by DeathBySnuSnu
The other header.
- 15086076865180.jpg (117.06 KiB) Viewed 6672 times
- 15086076956431.jpg (115.9 KiB) Viewed 6672 times
Posted: Sat Oct 21, 2017 1:57 pm
by DeathBySnuSnu
Posted: Sat Oct 21, 2017 10:32 pm
by Dusty-Dave
Well does it have enough vacuum span to run the map? Tighten that annoying belt.
Posted: Sun Oct 22, 2017 7:10 pm
by DeathBySnuSnu
That was the very first start.
A long ways to go on tuning yet.
I have ran several warm up cycles now.
Things are loosening up and settling in.
Getting over the start up hots.
Once the engine is run in enough (almost there) I will start tuning on it and chasing down the problems.
No do not know about the vacuum yet.
