Making a Seat ...
Seat making, Saddle Bags, Vests and other Fabric Work Information.
Making a Seat ...
Re: Making a Seat ...
I love your work!!
You are a big name to ME!!
I would like to see more of the engraving stuff!!
How do you make the art work and what paper did you use??
I draw some and copy a lot ... lol..... I size the art work to the size of the seat and print it out . Then I use clear plastic sheet and trace it on to the plastic.... I like to use an old roller ball ink pen that has on ink. The clear give you a easy way to position the art.( There is clear letter size sheet that you can print on .)I then use to pen to emboss the design into the leather. The leather has to be cased... ( wet ) and that is trial and error unless you have someone to show you. Tools can be made or bought.... if you make them , use stainless rod. Steel will leave black permanent marks on the leather. You can get cheap sets of tools at BSA. Scouts troops give lessons all the time.... learning to lace is not hard.... Tandy has a cheap book on basics... I will see if I have some links...
https://www.facebook.com/leatherworker.net
http://www.tandyleatherfactory.com/en-u ... /home.aspx
http://www.sbearstradingpost.com/freepatterns.html
http://www.bing.com/search?q=Download+F ... FORM=QSRE1
Thanks!!
Post by krymis »
yona,
working leather...how do you feel the handbooks seat write up is?
Don't know that I have seen that .... was off line for a while ....
Post by krymis »
That is a good write-up..... If you can't make a saddle after that..... step away from the motorcycle !!
Return to “Seats and General Leather Work”
