layering metal
An area for general welding posts that don't seem to fit anywhere else.
Re: layering metal
For those little tabs I would strongly suggest that you recut them using 3/8" (or 1/2") material to begin with as they probably won't be flat by the time you weld them together and then grind them down. This is one instance where taking a shortcut may not be a good idea even though in theory it will work.
Re: layering metal
Could you get fancy with some flush head rivets??
buellfun
SELF INTRODUCTION: I live in colorado. I have 5 boys. been married 20 years. just got my bike running. I am a sparky by trade. I am really glad to find the guys and gals from the old site. Looking forward to see the site grow and produce nice quality bike through the free infomation found on the board.
Re: layering metal
Post by buellfun »
Ok I will quit being a cheap ass. I guess i will learn how to use that 4th axis on the new mill. I was trying not to use any machine.
hell we will keep the pcs around for some large tab or brackets.
and as to the rivit, i was going to heat a grade 5 bolt then flaten the back side.
Chris
joechop
SELF INTRODUCTION: engineer working in construction industry and living outside of Pittsburgh PA. I recently completed my first build and hopefully more to come. officially started a side business for v-twin restomods... Vadori Designs.
Re: layering metal
Post by joechop »
....glad to hear
I think you'll be happy you went the non-laminated route
Return to “General Welding”
