Re: Where to have welds tested?
Posted: Thu Jan 10, 2013 6:43 pm
I cann't see the other pic, but understand what you're saying about the stress going through the straight line.
grassroots chopper building
https://choppercompendium.com/ccforum/
https://choppercompendium.com/ccforum/viewtopic.php?f=28&t=451
Sorry dude but all a visual inspection will tell you is what the surface looks like.fish11906 wrote:The ultimate test of your welding skills or abilities...build it than RIDE it.. Any reputable welding shop in your town should...remember SHOULD be able to do a visual inspection. They can also suggest methods for you to improve your skills or offer advice. Most guys who weld will be happy to help and show you some tricks and tips. Hope that helps some.
fish11906 wrote:I understand your view on the subject....I was simply offering an alternative to costly mag, radio, or ultrasound testing. Most common newb welder mistake is not running your heat high enough, which in turn leaves unpenetrated weld that can be easily spotted. The ride/test was my attempt at humor.lol. Guess it didn't translate that well. Practice, practice, practice....you'll only get better and find your comfort zone in the process.
It is.curt wrote: watterjet?
railroad bob wrote:I've been an inspector for many years, and have considerable experience with
Non-Destructive Testing (NDT). Also a CWI.
I personally second the suggestion to use practice welds and destructive test them.
2 of the common NDT methods are surface only, why bother...
PT (dye penetrant) uses a solvent cleaner, a dye, and a developer, each requiring a dwell time (you have to wait for a short time).
MT (magnetic particle) uses equipment to induce a magnetic field in the steel and the technician sprinkles a powder on the part. The powder
has iron filings in it with a dye color, and follows the flux lines. Any unusual indication breaks the flux line, and the powder follows.
Both are limited to surface inspection only. For frame welds, a thoro visual inspection does just as good.
UT (Ultrasound) uses expensive equipment and the technician is trained. The tech uses a handheld transducer to move in patterns over the surface of the material.
Needs to have a certain amount of space to do this, and the weld joint configuration is important.
You would not be able to get a useful scan on something like the welds on a fork neck. Possibly on a tube weld on a straight section of frame.
Very limited application here.
RT (industrial radiography or XRay) uses a portable radioactive source, is HazMat and regulated by the NRC. This method would have very limited application here also.
Round objects (pipe or tubing) require a minimum of 2 shots (xrays), usually more, to get a good view of all areas of the weld. Even then, it is possible
for an indication to be masked by other features.
Better to practice on the same material and joint configurations, get some good looking welds, get comfortable with it,
put one in a vise and tear it up, use a hammer, bars, reef on it like a mean mofo. If it breaks, see where and why, check it carefully,
use the lye solution suggested to check the penetration, all those things.
AA xray might be useful if you wanted to check the penetration on a final weld, one that will be a completed product you don't want to destroy,
but it will not be definitive that there is nothing wrong woth the weld.
Also, any inspection company doing inspection on something like this will not have any code to use when interpreting results,
and will not accept or reject a weld. They will also have disclaimers out the ass that this is only for information.
Again, very limited application.
May the Source be with you... (groan)
