Opinion needed
Opinion needed
I've had these Mounts on my Truck for Years.There are 2 & they support a Cooler Rack I use when Fishing.They usually hold up to 110lbs..This is how they sit
....I'm putting them on a different Truck & for them to mount where I need them the Plate needs to sit sideways like this .Does this look like it will hold sitting like this or should I add bracing?Changing the shape of the Earth...1 bucket at a time...IUOE local 825 top of the food chain
Re: Opinion needed
I would add braceing beer is valuable don't know if id trust one weld to hold 110 lbs of it
Re: Opinion needed
Bracing is good. Better to be sure.
Re: Opinion needed
Bracing will be added.I'll post a Pic of the Mounts when done....THANKS
- SELF INTRODUCTION: engineer working in construction industry and living outside of Pittsburgh PA. I recently completed my first build and hopefully more to come. officially started a side business for v-twin restomods... Vadori Designs.
Re: Opinion needed
Jeff - If I understand the concept, you really only need bracing on the underside. What's the span length (distance from tube to tube?) If the weld is good and 110lbs is max, probably don't even need it, but shear would be your primary force... and local bending of the plates. May want to move the bearing point / bolt connection closer to the tube Are you fabing new runners that run from plate to plate?
Re: Opinion needed
Probably WAAAAAY more that you wanted, but.....
I made some conservative assumptions (A36 steel w/ 0.33Fy allowable bending stress = 11.8ksi, 0.25"thick x 3"wide x 8" long) and came up with a max load of 46lb each bracket before failure due to bending stress. In reality you could probably stand on the end of the bracket and it may bend a little with a static load.
I'd run a lower support strut (will take the vertical load in a resultant axial force and transfer it to the circular tube via the weld) to the end of your mounting plate.... same width as the portion currently welded to the tube x say 0.25" thick. At those dimensions the buckling load of that strut would be 17kips (not even close to what it will see with your use).
Another option would be to better cross-section by improving the bending capacity. An easy way to do this woudl be weld a section of that round tube to the underside of the plate you currently have - notch it to "t" into the mounting tube and run it to the end of the mounting plate. ...Or use a small rectangular or square tube.
Again - probably WAAAAAY more than you wanted.
joe
joe
- JeffL1.jpg (94.8 KiB) Viewed 7106 times
- yona
Re: Opinion needed
Cooler rack...... didn't know there was such a thang..... my cooler sits on the seat of my truck...... between me and my fishing/hunting buddy !! .... ; )
Re: Opinion needed
This is what the Cooler Rack looks like
There is 30" between tubes that slide in the Mounts....I cut the Mounts apart & redesigned them.This is what I came up withChanging the shape of the Earth...1 bucket at a time...IUOE local 825 top of the food chain
