braising aluminium general questions.
Posted: Wed Nov 18, 2015 9:32 pm
I am building a set of mirrors, using 1/8" aluminium, I need to attach a aluminium block to the back of the mirror.
This will have the drilled 3/8" thread, for the rod to mount to the bars.
I can just drill holes through the 1/8 plate and counter sync the flat head the screws.
Problem is, I will mill 1/16 out of the back of the mirror, 1/16 out of the frame, sandwich the glass.
So the screws will now only be going through 1/16 into the mounting block.
I would also like to use some aluminium rod with flux included, pick it up at harbor freight, but already have.
You just use a propane torch to get the needed 750 degrees to braise aluminium.
Has anyone used this method before? can it hold the block? my mirrors have some weight to them, 1/4" thick plus glass.
What about polish? I will fly cut the mirrors and engrave the backs of them, will this aluminium rod look like a turd?
How about on a headlight and braising mounting tabs and brackets for a headlight bucket,, will it hold up in strength to that?
I have a small mill and a lathe, cutting torches and many machinist tools, will be a few months before can buy a welder, want to get started now. Do I need to wait?
