drill press, bench grinder single phase motor repairs
Posted: Sun May 06, 2012 3:16 am
by triker_chewie
most common prob with single phase workshop equipment
http://bodgersparadise.blogspot.com.au/
Re: drill press, bench grinder single phase motor repairs
Posted: Mon May 07, 2012 2:21 am
Good tips here. I'm always into saving a buck, recycling, etc.
This is stuff most folks don't have a clue about.
Thanks...
Posted: Mon May 07, 2012 10:22 pm
by triker_chewie
just tryin to give somethin back
Posted: Tue May 08, 2012 6:05 am
by Maxthegardener
Good post.....have found crap at the tip.....that just needs a it of TLC...need a new motor for my cut off saw, anyone know how to rejuvinate armatures?.....when you run the motor it arcs at the bushes then just died....what causes that?? have stripped it, got it going again, only happened again...they won't replace it, cause when I bought it apparently was a recondition return??? Did wonder at the time why it was cheap.....Doh??
Posted: Tue May 08, 2012 11:18 am
by gearhead1951
if you can make it run with the comutator exposed , push a piece of chalk against the rotating comutator ! This will clean and polish the strips and should make the motor run more efficently , other wise chuck up a drill motor to turn the affected motor while you use the chalk !
Posted: Thu May 10, 2012 9:55 pm
I've heard about using a pencil eraser to clean gold electrical contacts (gently as the gold is very soft), would an eraser work also?
Posted: Fri May 11, 2012 8:27 pm
by triker_chewie
too soft. the segments will just chop it up
