My 91 FXR EVO engine
Re: My 91 FXR EVO engine
sucks everything takes so long to get anymore
Truth right there...
Having problems finding the right gasket for the cylinder base.
Local independent ordered a set, but they were for S&S. ID was too large, but mostly the bolt holes were wrong locations
Terry Stewart said he can get the gaskets, but very expensive. And I'm not sure they would be right. Still searching.
No rush, I'm working an 8 week hitch up close to the Yukon River, so no way to work on personal projects for a while.
Still surfing for info and parts tho.
A few pix of the heads…
The order is reversed but they show the compression release from top and side, the material I’m considering for levers, and the position for operating the lever and release. I think the levers are from part of a light fixture, some scrap laying around.
Soft enough to bend and shape. I want to have an inverted cup shape above the releases and make a hinge that will mount to the underside of the head fin. Haven’t worked that out yet.
- F194CAF6-7EC5-4E42-BC4A-8E03B2654A21.jpeg (50.73 KiB) Viewed 16327 times
- 3AC2D904-267D-47AF-9829-5729102D2B87.jpeg (72.92 KiB) Viewed 16327 times
- 677E92D9-029C-4669-999A-D31960F839D9.jpeg (78.99 KiB) Viewed 16327 times
- FAA02648-6BD1-4A08-9A12-ED1AD17671CF.jpeg (56.32 KiB) Viewed 16327 times
- E9E9159D-D3A9-4BB9-9822-4E803A8AD822.jpeg (75.77 KiB) Viewed 16327 times
Hey Bob, loving the build! had any luck making progress in the last bit?
Hi Dan.
I got home a few days ago from a 6 week hitch. I was working up near the Yukon River.
Everything was on hold while gone.
BUT, I think I'll take the parts and a few tools with me next time up.
Sometimes I have some free time during and after work.
And there are a few good fabricators on the crew.
One guy is from Arizona. He does custom work, suspensions and body, when home.
Brian Bay at InclusiveMetal.com
Sharp guy.
I paid for the pistons, they're in the works. Having problems finding the right cyl base gaskets.
Everyone wants to sell me the S&S gaskets but the bolt pattern is wrong.
I have Delkron cases with an over sized cyl bore.
Piston arrival is weeks away, so no immediate need.
Sharp guy.
Through working this season, except for a possible short call out. Currently, I've been asked to be available for a project beginning mid to late February. Alyeska plans to replace a 48" mainline check valve. Considerable work. It's about 45 miles south of Deadhorse, so I expect 12 hour days because of the drive each day. They pipeline will remain in service, so there will be 2 bypasses required to maintain flow.
Current status of the engine rebuild:
Machine shop finish honed the cylinders for the new pistons. Could not find proper gaskets for the cylinders bases, so I'm gonna try out an unusual material. I've been told by a builder that he has used Garlock material, so I obtained some 1/16" thick material to use.
Not sure when I'll start assembly, other stuff keeps coming up. I'll have pics tho.
New pistons from CP
Picked up my cylinders from the local machine shop. One of several here. It's a new business started last year, but I've know the owner about 10 years. One of the finest welders I've ever met.
This is the Garlock gasket material I mentioned in an earlier post. I'll use the thinner which is right at 1/16". These are about 6"x6" so I should have plenty to trim to size, as long as I don't screw up.
Thanks for the Garlock reference. Seems like a superior product.
You may be familiar with the following procedure.
I watch Allen Millyard's builds.
https://www.youtube.com/watch?v=ZZvDnOMf8C0
https://youtu.be/ZZvDnOMf8C0?t=858
