Good oil pressure, and was an easy start.
https://vimeo.com/167203546
I have pulled it apart to get on with the rest of this build.
INSTALL A OPEN PRIMARY BELT DRIVE.....
Re: INSTALL A OPEN PRIMARY BELT DRIVE.....
The transmission came with a belt drive hub/sprocket.
Took it off yesterday, and am ordering a chain steup for this bike.
Had to remove the inner primary, but left all else in place.
I will use a 51 tooth rear sprocket I borrowed for mockup to set up the chain drive.
- TranyShaft.JPG (155.83 KiB) Viewed 5588 times
I used a chain on my build as well. definitely no room for a belt on mine either
Did you use HD parts ; what size is your rear tire?Jim Sawyer wrote:I used a chain on my build as well. definitely no room for a belt on mine either
I used a 1/2" offset front sprocket, and a stock HD flat rear sprocket . The offset sprocket is made by PBI
This chart shows some of their options
- offset sprocket.jpg (106.66 KiB) Viewed 5294 times
Thanks Jim, I got front and rear from PBI. Nice product.Jim Sawyer wrote: ↑Sun Sep 10, 2017 8:46 am I used a 1/2" offset front sprocket, and a stock HD flat rear sprocket . The offset sprocket is made by PBI
