Page 2 of 2
Re: My 91 FXR EVO engine
Posted: Wed May 18, 2022 9:29 pm
sucks everything takes so long to get anymore
Posted: Sun Jun 19, 2022 12:38 am
Truth right there...
Having problems finding the right gasket for the cylinder base.
Local independent ordered a set, but they were for S&S. ID was too large, but mostly the bolt holes were wrong locations
Terry Stewart said he can get the gaskets, but very expensive. And I'm not sure they would be right. Still searching.
No rush, I'm working an 8 week hitch up close to the Yukon River, so no way to work on personal projects for a while.
Still surfing for info and parts tho.
Posted: Sat Jun 25, 2022 12:41 pm
A few pix of the heads…
The order is reversed but they show the compression release from top and side, the material I’m considering for levers, and the position for operating the lever and release. I think the levers are from part of a light fixture, some scrap laying around.
Soft enough to bend and shape. I want to have an inverted cup shape above the releases and make a hinge that will mount to the underside of the head fin. Haven’t worked that out yet.
Posted: Fri Jul 22, 2022 7:59 am
by budoka
Hey Bob, loving the build! had any luck making progress in the last bit?
Posted: Tue Jul 26, 2022 10:36 pm
Hi Dan.
I got home a few days ago from a 6 week hitch. I was working up near the Yukon River.
Everything was on hold while gone.
BUT, I think I'll take the parts and a few tools with me next time up.
Sometimes I have some free time during and after work.
And there are a few good fabricators on the crew.
One guy is from Arizona. He does custom work, suspensions and body, when home.
Brian Bay at InclusiveMetal.com
Sharp guy.
I paid for the pistons, they're in the works. Having problems finding the right cyl base gaskets.
Everyone wants to sell me the S&S gaskets but the bolt pattern is wrong.
I have Delkron cases with an over sized cyl bore.
Piston arrival is weeks away, so no immediate need.
Posted: Thu Nov 24, 2022 3:47 am
Through working this season, except for a possible short call out. Currently, I've been asked to be available for a project beginning mid to late February. Alyeska plans to replace a 48" mainline check valve. Considerable work. It's about 45 miles south of Deadhorse, so I expect 12 hour days because of the drive each day. They pipeline will remain in service, so there will be 2 bypasses required to maintain flow.
Current status of the engine rebuild:
Machine shop finish honed the cylinders for the new pistons. Could not find proper gaskets for the cylinders bases, so I'm gonna try out an unusual material. I've been told by a builder that he has used Garlock material, so I obtained some 1/16" thick material to use.
Not sure when I'll start assembly, other stuff keeps coming up. I'll have pics tho.
Posted: Wed Nov 30, 2022 12:59 pm
New pistons from CP
- New pistons from CP
- New CP Pistons.jpg (84.54 KiB) Viewed 16124 times
Posted: Wed Nov 30, 2022 1:01 pm
Picked up my cylinders from the local machine shop. One of several here. It's a new business started last year, but I've know the owner about 10 years. One of the finest welders I've ever met.
- Cylinder.jpg (107.63 KiB) Viewed 16124 times
- Cylinder Bore.jpg (85.33 KiB) Viewed 16124 times
Posted: Wed Nov 30, 2022 1:05 pm
This is the Garlock gasket material I mentioned in an earlier post. I'll use the thinner which is right at 1/16". These are about 6"x6" so I should have plenty to trim to size, as long as I don't screw up.
- Garlock.jpg (68.63 KiB) Viewed 16124 times
- Garlock thk.jpg (69.65 KiB) Viewed 16124 times
Posted: Thu Jul 13, 2023 2:43 am
Thanks for the Garlock reference. Seems like a superior product.
You may be familiar with the following procedure.
I watch Allen Millyard's builds.
https://www.youtube.com/watch?v=ZZvDnOMf8C0
https://youtu.be/ZZvDnOMf8C0?t=858
