After 4 years of tinkering on a Softail build for longer travel, I finally got her on the road. Put about 100 miles on her last weekend, but found I had broken a rear shock bolt.
sheared it clean off in the swingarm.
Any of you seen this before. The other 3 bolts were still tight and loc-tited. my gut tells me it was a bad bolt, but always like to cover my bases.
It was a blast to ride while it lasted. Smoothest, and plushest Softail I have ever rode. This 114 Demon w/ 2.91 final drive just purrs @ 70 in 5th gear at 2600 rpms.
first 100-115 miles only used 1.1/2 gallons during break in too. Motor pulls well, even though I haven't had it over 3500 rpms yet.
thanks!!
Softail shock bolt
- SELF INTRODUCTION: I was a memeber on the old site, but couldnt log in here. I have a small shop where I do resto/ mods, build complete bikes (6 to date) ground ups. Been working @ Drive train specialists since 02 building custom automotive axles.
Re: Softail shock bolt
ya ive seen a couple of those they can be a real bitch to get out sometimes i dont kno if its bad bolts or bad design i also wonder if its because one shock is doing more of the work takeing more stress
Got the broken bolt out. heated loc-tited area w/ a heatgun, didnt want to screw up the powdercoating.
the other 3 bolts were tight still. re-tapped all the holes, all new bolts, and torqued to 105#.
I did see the shocks were slightly different in length, less than 0.050", but dead-nutz now.
hope to roll tomm!
Thanks!
hope to roll tomm!
Thanks!
