jonester springer build
- jonester123
Re: jonester springer build
Been a while, but i am still building my springer front end slowly. Last one to cutt out to shape the spring perch plate, then finish final shapeing perfectly. Once that is done then i will get the rockers traced out on new plate material and start cutting them out to shape. Not given up just so many projects to make progress on at the same time, sometimes i wish there was three of me to get stuff built faster hahaha. http://i893.photobucket.com/albums/ac13 ... 0_0427.jpg
- jonester123
Well been working on cutting out the flatside rockers material, gotta get some more cutting disks to hopefully get them all cutt out to rough shape. All holes have been center punched and drilled out a little for alignment. http://i893.photobucket.com/albums/ac13 ... 0_0428.jpg
- jonester123
Made some more progress on the springer build got them all rough cutt out to shape, a little belt sanding to make exact. http://i893.photobucket.com/albums/ac13 ... 0_0439.jpg
- jonester123
Getting back to building springer front end, been so crazy with other work. Now I have my new drill press and big holesaw kit to get them drilled out to size needed, so a lot of progress will be coming soon.
- bth_100_1718_zpsecb2c180 Drilling out springer parts with holsesaws.jpg (9.97 KiB) Viewed 9372 times
- jonester123
Some more drilling progress on springer parts, slow going sure are big holes. Thank god for holesaws
- bth_100_1719_zpse524e76a Lower springer perch plate drilling.jpg (10.68 KiB) Viewed 9356 times
- jonester123
Hey guys and gals, going to be finally ordering springer tubing and the springs this month. So hopefully get this springer build further along, been very busy with all my projects plus my 1980 Camaro rebuild.
ME WATCHING!!
You need to finsh this I want to link it to all that do not belive a springer can be built with grinder and drill press by a garage builder!
- jonester123
Hello CustomizeIT , been finishing my hardtail frame build. Check it out in project build section, almost done, got to do all the final welding. Then back working on springer front end build.
- SELF INTRODUCTION: I was on the old forum, I have more tools and more projects now, I have a wide range of projects , home built boats, a few buggies, snowmachines and a few snowhawks, latly I have been collecting old broken machines most recently a marvel roll in bandsaw, and a old lathe that needs some love from 1908, and about 10 bike projects, most were not running when i got them , same with my mill and bandsaw I had to get them operable. Looking to further my knowledge and share what i can offer..
Right on, noticed your in b.c. Almost local to me....by about 7hrs, ha
- jonester123
Hello dirtbag, yes I am in the Okanagan Valley area.
- jonester123
Well , another pic of progress on springer build. About half way done all the drilling, then need to do final shaping of all parts on grinder. Got list ready to order the springs and tubing materials. More coming soon.
- 100_1755_zps14af35dc springer build.jpg (245.35 KiB) Viewed 9288 times
- jonester123
Springer tubing arrived for build today, $108.50 total cost
- 100_1771_zpsaafe9601 springer tubing.jpg (226.72 KiB) Viewed 9241 times
- jonester123
Hey guys and gals, been doing mockup of springer front end build.
- 100_1795_zps09f8f796 springer mockup 3.jpg (200.66 KiB) Viewed 9219 times
- 100_1794_zps80679261 springer mockup 2.jpg (232.76 KiB) Viewed 9219 times
- jonester123
Took apart steering stem from stock Honda neck, using it for springer build.
- 100_1789_zps4aff79ee springer front end steering stem fab.jpg (188.03 KiB) Viewed 9208 times
