girder rake and trail prior to frame manufacture
Builder52
SELF INTRODUCTION: I worked on, bikes since I was 14, I progressed to cars when I hit the age of 16, now at 52 I find bikes more rewarding to build and with less space now to store my toys ( 3rd house, also the smallest garage) I use parts from anything that I can find to fit, my builds and am rapidly becoming a decent tig welder. Still I dont know everything and find it expensive to build from a catalog. so that is why I am here for the second time. I can only imagine what happened to my old post since I cant find them and very few of the old crew that used to be on here. maybe we can all come back on and share all that knowledge we acquired over the years of building? xp
Post by Builder52 »
Ok I have a girder (ebay purchase )that i have and would like to figure out the frame rake and trail. when I read some of the posts it seams the frame is already figured out but I have not made the frame yet.I am going to make a low neck height frame. now my question is : what measurements are needed to figure out the frame? I have looked at Nero's post and have taken down some calculations he has made, for his and will measure mine in inches and post my findings.
Builder52
Re: girder rake and trail prior to frame manufacture
Post by Builder52 »
hmmm ?
TattooLeeRoy
Post by TattooLeeRoy »
As you may have gathered, thats not an easy place to start. Do you know what frame it was supposed to fit?
Start with a front tire, block the assembled front end at the height you want your neck. Measure the rake and trail, figure out what to do from there.
Thats a pretty crude way to do things, but its all I can think of to help.
TattooLeeRoy
Don't forget to keep the girder links level for set-up,
I know its not a girder but I believe this is what TattoLeeRroy means.
thats a nice jig there
Those are build log pictures by BarefootJerry. He used to post on the previous site to Choppercompendium. I haven't seen him since then.
TattooLeeRoy
Yes, thats the idea. Glad it made sense to someone.
Builder52
Post by Builder52 »
TattooLeeRoy wrote:As you may have gathered, thats not an easy place to start. Do you know what frame it was supposed to fit?
yes I gathered that, being from an automation background I have very little hesitation with doing things the hard way .
Builder52
Post by Builder52 »
TattooLeeRoy wrote:Don't forget to keep the girder links level for set-up,
level with the ground and lower frame rails, or paralell :think:
Builder52
Post by Builder52 »
hansgoudzwaard wrote:I know its not a girder but I believe this is what TattoLeeRroy means.
Y know I have a frame jig and have never used it that way, damn good Id re. with a girder it needs to be design with a 1" load drop when you hook it up to the frame, motor combo so it will sit right. might compress the front end and simulate the load to get an accurate measurement. :think:
Builder52
Post by Builder52 »
thanks to all for replying and its def givin me some directions !!!
Builder52 wrote:[ might compress the front end and simulate the load to get an accurate measurement. :think:
You could let some air out of the tire to simulate(eq. to 1") if that was easier.
