my production springer
Posted: Fri Nov 08, 2013 8:52 am
the springer i am doing custom production orders on...that's right i am posting full size blueprints to my production run.
it is a springer that utilizes the same top four plates for all 3 widths. the widths for a narrow glide using a 3" or smaller spool hub, a mid glide using 2000-2012 equivalent sportster hub, or a wide glide using common wide glide hubs.
the following attachments are the width between legs spacing with the lower tree. the tree is designed to hide the 2.5" chopper neck or dust cover. it has a 4" inside width between the 1.25" rear legs.
i also have 4 different tree setups i use. i have an inline, 1" offset, 1.5" offset and a 1.75" offset
