Opinions needed
Posted: Wed Nov 08, 2017 9:34 pm
Re: Opinions needed
Posted: Sun Nov 12, 2017 10:38 pm
i have a set of rockers that are 3/8 and fairly long at 11 inches between front and rear hole
Re: Opinions needed
Posted: Mon Nov 13, 2017 10:18 am
I have a springer with 3/8 rockers too. Made in the 70s & they're still straight. The ones for this build will be pretty short, but think I'm gonna go with 7/16. I also started on new legs with more material at the bottom.... thanks man
Re: Opinions needed
Posted: Mon Nov 13, 2017 9:35 pm
I cut a slot in my rear legs and welded in a tab, 3/8 thick. I used 1 1/4 Inch tubing for the rear legs.
I'm sure what you are doing will work fine.Your pivot bolt will be held by the slot. Solid material looks pretty strong.
- tab.JPG (28.35 KiB) Viewed 6425 times
Re: Opinions needed
Posted: Wed Nov 15, 2017 9:17 pm
I wasn't feeling to confident in the legs, so made up some new lowers. I'll be able to step up to 7/16 for the rockers have room for bushings & still have 1/2 left on either side. Much happier with these.
- IMG_1650.JPG (137.8 KiB) Viewed 6416 times
Re: Opinions needed
Posted: Thu Nov 16, 2017 11:00 pm
i like it
