curts springer build
im about 3/4 done building my springer but now that were on the new bord ill try and get things caught up ill start with pics from the other bord then catch up as soon as i can i got progress on all my builds and started another too
- springer build 2 002.jpg (62.31 KiB) Viewed 6835 times
- springer build 2 001.jpg (56.73 KiB) Viewed 6835 times
- springer build 1 008.jpg (57.18 KiB) Viewed 6835 times
- springer build 1 007.jpg (56.52 KiB) Viewed 6835 times
- springer build 1 001.jpg (39.58 KiB) Viewed 6835 times
Re: curts springer build
i dont know how many pics it will let me load at once so sorry for the choppieness
- springer build 3 004.jpg (49.26 KiB) Viewed 6833 times
- springer build 3 003.jpg (64.34 KiB) Viewed 6833 times
- springer build 3 001.jpg (44.65 KiB) Viewed 6833 times
- springer build 2 005.jpg (53.82 KiB) Viewed 6833 times
- springer build 2 003.jpg (60.08 KiB) Viewed 6833 times
Looking good dude
- jonester123
Hi curt, looking good man. We all have alot of pictures of our builds to repost so slow and steady man and we will all get the new forum up and running awesome.
wait i got lots more
- springer build 6 002.jpg (52.91 KiB) Viewed 6827 times
- springer build 6 001.jpg (56.29 KiB) Viewed 6827 times
- springer build 5 006.jpg (50.36 KiB) Viewed 6827 times
- springer build 5 004.jpg (49.38 KiB) Viewed 6827 times
- springer build 5 001.jpg (45.06 KiB) Viewed 6827 times
- springer build 4 004.jpg (48.49 KiB) Viewed 6827 times
one more then i can get to the new stuff
- springer 8 004.jpg (55.35 KiB) Viewed 6825 times
- springer 8 002.jpg (63.89 KiB) Viewed 6825 times
- springer 8 001.jpg (55.36 KiB) Viewed 6825 times
- springer build 7 003.jpg (45.88 KiB) Viewed 6825 times
- springer build 7 002.jpg (57.78 KiB) Viewed 6825 times
- jimmib
Coming along nicely Curt. Got tubing for the legs yet? (never mind my question, you must have been posting pics while I was typing)
Looks great though.
Looks great though.
Looks like you got that sucker mostly built already.... guess we all got a lot done while the old board was down......
keep posting dude, that's a great front end and I can't wait to see it on your scoot
ok now the new ones
- springer 10 003.jpg (52.96 KiB) Viewed 6824 times
- springer 10 001.jpg (48.44 KiB) Viewed 6824 times
- springer 9 004.jpg (48.26 KiB) Viewed 6824 times
- springer 9 003.jpg (44.77 KiB) Viewed 6824 times
- springer 9 001.jpg (40 KiB) Viewed 6824 times
ok took me some time to track down the wheels i want to use had to settle for a fat boy rear but ill change it out later for a spoke wheel got the rear on and had to make a stand for the front because i dont have a tire yet but i know the height when the tire is on because its the same as the one on my dyna . got the frame proped up where i want it to sit at when im rideing it measured and cut the rear legs i fishmouthed the tubes and welded on the ends for the rockers . now that i got them done i gotta get outa work early enough to hit my friends shop hes got a much bigger lathe so i can fit the tubs through the chuck and square them up and make shure theyre exactly the same length . hoping i can get free tomorrow .i got my springs and rods and all the hardware for those took some time to figure out the reamer (thanks dan for the help while going through all the nightmare of the old bord and new and your knuck ) it turns out its a taper pin reamer number 8 and if ya drill the hole 7/16 it saves a lot of reaming . once i got the first hole done and knew what size the hole was i stuck drillbits down the hole till the bigest one fit through the small end and drilled the other hole with it then it was a very light ream just had to put the taper in it and a lil more gotta b carefull . then i put the springs together i made a tool to do it it was real easy to make from scrap ill post some pics tomorro left work so i could try and make my friends shop before he left didnt make it oh well tomorrows another day
startin to look like a bike finally hopefully i can start welding it up tomorrow its a little over 9 feet long from back tire to front rim and nice and low gonna have to build an extension for the lift i think
forgot i also made the stem i found a 1 inch bar in the scrap pile that had no rust on it yet turned down the threads on the lathe picked up the nuts for the bearing and tree from j&p cycles from the partnumbers on the plan welded it to the bottom tree droped in the bearings and bolted it together for a trial fit the holes were perfect the sholders fit perfect cant wait to start welding it up
that really is good work dude......lovin the style from the mock-up pics.......
thanks i really like the long and low look it should give me enough room for that oiltank on the front of the frameMaz wrote:that really is good work dude......lovin the style from the mock-up pics.......
Fer all the dumpster divers out there , the shaft out of wornout and discarded shocks and mcpherson struts is an ideal source of neck stems , springer spring rods and a lot of other applications !
They come in many sizes but are uniformly very hard and TOUGH !!
