Rear brake issue on new build
This is for posts and questions about the above subjects.
monkeywrench202
SELF INTRODUCTION: I was a memeber on the old site, but couldnt log in here. I have a small shop where I do resto/ mods, build complete bikes (6 to date) ground ups. Been working @ Drive train specialists since 02 building custom automotive axles.
Post by monkeywrench202 »
loss of brake pressure
Hey guys,
I am having an issue I have never had before. I have bleed 100's of systems thru the years, but this one just makes no sense.
Rear line, 4 piston Wilwood caliper, standard HD softail Master cylinder, pressure switch for brake line inline.
No matter how much I bleed this thing, I cannot keep pressure. if you spike the pedal, it has great pressure and grabbbing power, but if you gently push the pedal, it sink to the bottom w/ zero resistance. If spiked, it will hold also, no bleed down/ sink.
Light works when spiked, but not when pushed slowly?
Any ideas?
I have bleed and bleed, no air is coming thru, it solid clean fluid.
Been considering a Pheonix tool bleeder, but never needed one B4?
Re: Rear brake issue on new build
Look to the MC....something is letting fluid bleed past the seals .... do these Mc's have a bypass built in ..... ???
ive had that problem on the front useing the small master 9/16 switched to 11/16 was fine but i have noticed sometimes useing harley brake parts with aftermarket can sometimes do that might think about switchin to a better master let us kno what u find
monkeywrench202
Do you have a recommended MC that fits FLST floorboard mounts? 1996 style floorboards?
Russ
SELF INTRODUCTION: I an indepent biker, no offence to patch holders but I can't be bothered with all that tough guy stuff. I'm into old BMW boxers. Low budget builder. I like my family, my bike and not much else. My current project is an r100rs Beemer that was posted on the old chopperhandbook site under the title "Another BMW gets attacked with a hacksaw".
Post by Russ »
Might be the seals. It's not unknown for 'soft' seals to get past quality control.
im not sure floorbords are a definate pain in the ass cause your locked in to the master that attaches to the frame unless u make a custom bracket then you can run about anything you want
monkeywrench202
Must have been a Monday or Friday MC. fragments of crap in it. Rebuilt the MC and got the best brakes I have ever had on a scoot.
Thanks guys!!!
cool glad ya got it going
Return to “Wheels, Tires, Sprockets, Belts, Chains and Brakes”
