Slow Build
Re: Slow Build
railroad bob wrote:Curt's shim solution sounds like the way to go.
Looking at the front mount, are you planning a gusset plate between the vertical and horizontal plates shown?
Yes, I am going to beef it up . It won't be strong enough as is.
Re: Slow Build
I was taught to use the rear motor mount as the 'good one' even if it was 'off' and then shim the front. Try to match the tranny mount to the rear motor mount if you use this advice. I have yet to see a chassis, factory or otherwise, where all three planes were spot-on.
Re: Slow Build
gww25 wrote:I was taught to use the rear motor mount as the 'good one' even if it was 'off' and then shim the front. Try to match the tranny mount to the rear motor mount if you use this advice. I have yet to see a chassis, factory or otherwise, where all three planes were spot-on.
Thanks Gary, and thanks to everyone.
Re: Slow Build
if you can use a steel shim and try to tack weld it to the frame it sucks when you forget to put it in depending how much it is shimed you could crack a case or cause oil leaks in the factory split
Re: Slow Build
curt wrote:if you can use a steel shim and try to tack weld it to the frame it sucks when you forget to put it in depending how much it is shimed you could crack a case or cause oil leaks in the factory split
Thanks Curt, I won't forget the shims.
Re: Slow Build
I did an online search on shimming the HD. This is a big problem with many responses on many forums.
So thanks for the heads up, and we will attempt to do a proper install before anything else.
Motor Co. Bulletin M-1324:
https://app.box.com/s/gc2vp815yihg8g82g51e
My setup is different but it does apply for all 1990 and later Dyna model motorcycles.
Someone here may have use for this.
Re: Slow Build
Thanks, works for my bikes...
Gonna get on with it
It's So Purdy!
It's So Purdy!
Arrived last week;
Open primary , 6 speed trany, spoke wheels, Starter.
Working on the oil tank now, will be finished welding it today.
Check for leaks later. Or maybe I won't check for leaks, it will keep the chain oiled? :-? :lol:
Something new for me
Re: Slow Build
Poured a cup of gasoline in the tank, swirled it. I seem to have 2 small leaks , one along a bottom seam, the other on the outlet fitting.
Blow the tank with air before I try to fix the leak.
Re: Slow Build
Is there a specific reason you used gas to test for leak? I think I'd do a little more than just blow it dry with air. Love that primary man.
Re: Slow Build
It flows well. Through the tiniest pinhole. I was going to use laquer thinner , but didn't have any.
I made sure it was all evaporated before I repaired it .
The primary was the least expensive one out there . Made in the U.S. I really like it.
It fit my budget too.
IRISH
SELF INTRODUCTION: Hi All,
Craig
Re: Slow Build
Post by IRISH »
Hans, on the motor mounts, why dont you just cut the welds on the rear one, or the front one, bolt the case in tight and re tack whichever mount you cut loose. If you tack weld it in 4 places it should stay in place when you weld it. Better than having to use shims. What type shims? Flat washers?
To do it so everything lines up, you should bolt the case to the mounts, install an inner primary cover and bolt the trans case in and attach your mounts and then tack weld all the the mounts, engine and trans, to the frame. It also is a good idea to have the rear wheel centered and install the rear belt, or chain, so you can make sure everything clears the rear frame tubes. Thats the way I'm going to do mine.
Re: Slow Build
I am going to leave the motor mounts; there is only .005 clearance so washers could be used , but I will shim.
Today I cut out the rear trany mount to reposition it.As you suggest, I am going to line the rest up to make sure everything is in alignment.
I had to take a slice out of the seat post to get the 6 speed some breathing room.
Good to hear from you, Irish. Will this be your second or third, build? I remember your first very well.
rusty and ratty
rusty and ratty
IRISH
Craig
Re: Slow Build
Post by IRISH »
Hi Hans, It's my second with building the complete frame. Craig
