Isabucket hopes this helps?
Step 1 in spraying paint Shake the can. When you think you have shook it enough shake it some more. You will notice I right the mix ratio on the top of all my paints when I buy them at the store from the guy who should know. This one is 1:1 ratio paint to hardner.
Step 2 read all the directions for each application you are spraying. Make sure you know the ratio mixture and what it is mixed with if not call the guys at the store.
I always store my paint gun tips submirsed in laquor. It does not evoporate will be there for yrs but, the tip will be ready to go clean when you go to use it. Pull it out put on the gun and spray some of the laquor out to make sure gun is clean.
Pour the laqour into a cup or coffee can for clean up latter.
Clean the gun with a paper towel and pull the trigger dry after to remove any laquor residude left in the gun.
Even thou you shook the dog shit out this for what seemed to be forever! Use a paint stick and mix the paint or application you are applying.
You read the directions and are sure 1:1 so find that on a mix cup. Some may be 2:1 or 2:1:1 just find that on the cup. Any questions call the guys who sold you the paint they should know! Know put a PAINT Filter in the cup can be seen here
So 1:1 pour paint in first always! Not much needed this shoot so 1 and 1/2 or something. MAKE sure to pour thru a paint FILTER. Sorry forgot that pic I guess.
Now the catalist for this particular application.
Pour the catalist in to about the same level on the cup. You do this right and will never need to adjust your gun after the first time.
Use the paint stick and mix the 2 together.
Count the drips off the stick after it quits flowing. Should be between 8 to 13 drips 10 being really good! This will tell you if mixed right or will even shot thru your gun. You can add more paint or catalist to get to the proper drip count but anything 8 to 13 will shoot!
Pour the mix back thru the paint filter you moved from the cup to the gun when mixing.
Use a tack cloth in a sweeping fasion never sitting in one place to remove all the fine dust after air blowing.
NEVER go directly to your work with the gun and paint! Always make a small shoot to test and get any laquor left out the nozzle so, only proper mixed paint goes on your work.
Paint the part or parts you want painted. Do not watch where you are painting but the coat behind the spray and set your speed to that for coverage. Always start before the part with paint and pass it before letting off the trigger.
Now the laquor you put off the side earlier that was in the gun when you got there pour back in to clean it.
Shoot some out to get the nozzle cleaner. Wipe with your hand and a paper towel and also clean the outsaide of the gun.
Now pour that dirty laquor left over from the small start clean shoot into your cup to be cleaned latter.
Use a paper towel and clean your gun and cap for gun.
Put fresh lacquor in and make a shoot of clean lacquor thru the gun for a few seconds.
Put the nozzle back in the gun and put it up in storage.
Use a paper towel to clean your cup with the dirty lacquor out the gun.
Clean cup.
Make sure to beat the lid down on your paint can so it does not get a film and is fresh.
