Page 8 of 12
Re: 1979 Honda CB750 Bobber build
Posted: Sun Feb 12, 2012 8:16 pm
by jonester123
Posted: Mon Feb 13, 2012 2:54 pm
by jonester123
Metalbender, that would be great if you could machine up some solid stock sleeves 3 of them . Size of new tubing is 0.62" and old tubing is 0.61" inside tubing sizes, let me now what shipping costs would be to Armstrong B.C Canada V0E-1B7. Thanks.
Posted: Mon Feb 13, 2012 3:02 pm
by Metalbender
Hey no problem, how long do you want them to be? Or do you want me to just make them like 6" and you cut them to size?
Posted: Mon Feb 13, 2012 3:20 pm
by jonester123
Hi man, i think about 5" long should be good. As long as they slip into each size tubing about 1" or so inside, does that sound safe enough.
Posted: Mon Feb 13, 2012 6:40 pm
by jonester123
Well, decided i better put some paint on my rear fender since it was trying to start with some surface rust. All i had is some yellow spray paint on hand so i put three good coats on it for now.
http://i893.photobucket.com/albums/ac13 ... 0_0384.jpg
Posted: Mon Feb 13, 2012 10:40 pm
by Metalbender
This is my first build so i'm far from an expert but I read that slugs should be double the tube width. So if your using a 1" tube you would want a 2" slug minimum. Maz could prolly be able to give us some pointers there.
Posted: Mon Feb 13, 2012 10:47 pm
by jonester123
My new tubing size is 1 1/8" wall thickness .125, so one inch solid stock machined down to the sizes i mentioned should be fine. As long as the sleeves are a nice good fit, then i can plug weld them in good and solid. I printed out the sleeve information so i will try to find it and send you a copy of how it should be done.
Posted: Mon Feb 13, 2012 11:14 pm
by jonester123
Metalbender, found my copy of sleeve or slug information. If you would like a copy of it let me now your email address and i will send it to you.
http://i893.photobucket.com/albums/ac13 ... 0_0391.jpg
Posted: Fri Feb 17, 2012 5:40 pm
by Metalbender
Hey, sent you a pm, I can ship your slugs on Monday just need an address
Posted: Fri Feb 17, 2012 6:19 pm
by jonester123
Posted: Fri Feb 17, 2012 9:37 pm
by jonester123
Well been shopping looking for a descent light setup for my chopper build area in workshop, found a 500 watt halogen stand light that plugs into outlets and i can move it around workshops if needed. Good price on sale for $40.00 and the tube lasts 5000 hours.
http://i893.photobucket.com/albums/ac13 ... 0_0401.jpg http://i893.photobucket.com/albums/ac13 ... 0_0400.jpg
Posted: Sat Feb 18, 2012 7:19 pm
by Dan.in.Can
you might know a way around it, but figured i'd mention it. i recently ordered my die set from jd2 and had it shipped, it was only $40 shipping, i thought that wasn't too bad untill it showed up and there was a extra $98 brokerage fee i had to pay to get it. just a heads up, the shipping/brokerage might be more than having them made locally.
Posted: Sat Feb 18, 2012 7:34 pm
by jonester123
Hi Dan.In.Can, i get my jd2 bender dies from tmrcustoms. Good prices but yes it still costed me an extra hundred dollars for shipping etc, they get you one way or another. If you want quality you need to pay for it i guess. Metal bender is makeing me tubeing sleeves for my hardtail build not a die, should be relatively cheap for very small items to ship etc.
Posted: Sun Feb 19, 2012 5:26 pm
by jonester123
Well, back to the jd2 bender 8 ton air hydraulic ram mounting bracket fabrication. Seeing what materials i got to figure out the bracket mounting, got to get this thing built somehow so i can get useing the bender for my hardtail build etc.
http://i893.photobucket.com/albums/ac13 ... 0_0408.jpg
Posted: Sun Feb 19, 2012 7:40 pm
by jonester123
Here is another progress picture of bike being setup in bike build area only.
http://i893.photobucket.com/albums/ac13 ... 0_0409.jpg
