So, as some of you may recognise me from another forum...this is my first build....it is still undergoing construction, but since I am new here, I thought i'll share my sickness with you...
started off with a Buell xb9 engine, some xb parts from E bay...front end and rear swinger and a couple of wheels....
I built the jig first and then bought the original frame to set the jig fixtures accordingly since I wanted to retain all the buell geometry in the frame build...
FIRST BUILD BUELL XB9...sort of
- SELF INTRODUCTION: Ok, i am from Gozo, Malta, a very small island in the Mediterranean... i work as a Renal Nurse at the local General Hospital and like to chop motorcycles and build all the odd things for bikes. I mainly work with steel but like to incorporate my skills into other metal fab as well especially stainless steel and aluminium.
- Image0068.jpg (215.36 KiB) Viewed 4039 times
Re: FIRST BUILD BUELL XB9...sort of
The original frame
- Image0070.jpg (243.12 KiB) Viewed 4037 times
measuring.....zzzzz
- Image0103.jpg (225.63 KiB) Viewed 4037 times
constructed a triangular section to form the upper part of the frame...and drilled lightening holes in it...plugging them with stainless tubing
- Image0167.jpg (173.75 KiB) Viewed 4006 times
the tail section....sort of trellis frame...will have to hold the fuel tank..
- P280112_1403.jpg (55.82 KiB) Viewed 4006 times
taking shape
- P280112_1436.jpg (83.19 KiB) Viewed 4006 times
skeletal structure coming along
- P280112_1440.jpg (60.49 KiB) Viewed 4006 times
Cool backbone, hope you plan on leaving it exposed to view.
Fuel in tail section?
spine back bone will remain exposed and the fibreglass fuel tank fitted in the tail section
Might consider carbon fiber. Similar construction, looks better when polished, no need for paint.
