Irish's CBH CR200
IRISH
SELF INTRODUCTION: Hi All,
Craig
Irish's CBH CR200
Post by IRISH »
I started (again) on the new chop this past week. I got the seat post x-member and seat post fish-mouthed and cut, and also mitered the rear wishbones. I'm using the blueprint from the CBH for the CR-200 (Custom Rigid) with wide rear wheel. I'm using a 1.5" backbone instead of the 1.25". I also want to use a single down tube instead of the double tubes running up from the front motor mount. I'll bring the lower rails together just above the front mount and run another 1.5" tube up to the head tube.
seat post cross member and seat post mitered and cut to length ready to tack
I scored a vintage Randy Enterprises springer fork that is quite long, 34.5" from the lower tree to the rear rocker pivot, so I want to stretch the backbone and down tubes more than what the plan calls for; how much more I don't know yet. I need to get the rear wheel and tire bolted up and then I can mock up the front and get the look I want. I ordered a 18x5.5 rear wheel for the project and I will mount a 180 or 200 tire. I will probably run a chain final drive to keep it narrow.
The springer came with a 18 inch Hallcraft's front wheel and mini drum which I'm selling on ebay. I'll use a 21 inch narrow glide disc brake wheel up front so the bike will stop. I need to shape up the rockers, or build new ones as the original Randy's are a goofy shape (70's). I also need to find a 1"-24tpi die to fix the stem threads as some idiot beat them up for some reason - probably trying to keep the top nut from coming loose I guess.
14 over Randy Enterprises front end
I used the Tube Miter program.
rear wishbones getting fitted to 1 1/2" backbone
final fit up is nice and tight
Re: Irish's CBH CR200
The joints look nice.What program did you use.Forget which one I had, but my computer crashed before I got a chance to use it.
IRISH
Craig
Post by IRISH »
Tube Miter by Giles Puckett: http://www.ozhpv.org.au/resources/shed/tubemiter.html
It's the same one I used on the first one. You have to convert to mm. Works really nice.
Nice Start! :popcorn:
IRISH
Craig
Post by IRISH »
Thanks Jeff and Max.
Day 2: I tacked the top tube to the seat post. Then I welded two lengths of 1" angle to the cross bar on the jig to hold the seat post cross member in place. I then wanted a support for the top tube so I set up a length of 1x2 rectangular tube at 25 degrees from horizontal and used a 1.5" hole saw. I then sawed through the center of the hole. I will weld tabs to each side of the pieces and drill and tap them to make a clamp to hold the top tube in place.
As I mentioned earlier I am build the jig as I build the frame so I can reproduce this frame over and over in the future. I am going to make the head tube fixture adjustable so that the rake and height of the head (steering) tube can be changed for different degrees of rake and position. That's next.
ok, ok, you are having waaaaaaaay too much fun. can i come over and play?
i've gotta get done with this moving crap so i can get on with putting the knuck back together.
good luck to ya as you progress!
IRISH
Craig
Post by IRISH »
You are welcome anytime Dan! Thanks! It is fun to get back to fitting a frame together. I sold the old front wheel that came with the springer so I'm shopping for a 21 now.
Nice start Craig, and I think making the jig as you go allows you to make decisions and changes
that are hard to foresee without a huge amount of pre-planning. Should save you quite a bit of time.
Good idea...
IRISH
Craig
Post by IRISH »
Thanks Bob. It's fun as hell too!
IRISH
Craig
Post by IRISH »
OK another update: Over the past couple of days I got the upright that will hold the back bone (top tube) welded in place between the jig rails and I welded two tabs on either side of the notch at the top of the upright so I could attach a U-bolt (which is actually a 2-1/4" muffler clamp I had laying around) to hold the top tube firmly in place in the notch. I realize that this upright is not adjustable for height at this point, but later on if I want to change it for a different frame I can make it adjustable. I'm trying to do this as simply and inexpensively as possible, so I am trying to use materials from my scrap heap.
So after I completed that I clamped the tube in and lined everything up. I beveled the bottom of the seat tube and tacked it to the cross member. I then pulled the assembly out and welded it out on the bench. Next I'll attach the rear wishbones to the top tube and then it will be time to bend the lower rails. I may need to get some more tubing as I only have 10 feet left and I'm not sure if I can squeeze both bottom rails out of that or not. I am going to use a single lower down tube from the neck, so maybe...
IRISH
Craig
Post by IRISH »
I also cut and drilled some aluminum plates for the adjustable neck holder. I need to decide whether to use 3/4" round bar or threaded rod for the neck holder. I am thinking of maybe using round bar and boring a 1/4" hole in the end to be used as a pilot hole for a hole saw for cutting the top and bottom tube notches for the neck.
im always jealous of you guys able to keep your shop that clean while working on a project
Russ
SELF INTRODUCTION: I an indepent biker, no offence to patch holders but I can't be bothered with all that tough guy stuff. I'm into old BMW boxers. Low budget builder. I like my family, my bike and not much else. My current project is an r100rs Beemer that was posted on the old chopperhandbook site under the title "Another BMW gets attacked with a hacksaw".
Post by Russ »
curt wrote:im always jealous of you guys able to keep your shop that clean while working on a project
Same here.
Irish's work shop is cleaner than my kitchen.
now THAT'S what i'm talking about! get off the friggin' couch, tell the reality shows to kiss your ass, and actually live some *reality* yourself. that's exciting. and there's too little of it today. that's why people from way back when are worshipped today...they were too busy *doing* to care what anyone else thought.
keep her coming along, man. we're hanging on the edge of our seats over here, waiting. :banana-dance:
budoka wrote:now THAT'S what i'm talking about! get off the friggin' couch, tell the reality shows to kiss your ass, and actually live some *reality* yourself. that's exciting. and there's too little of it today. that's why people from way back when are worshipped today...they were too busy *doing* to care what anyone else thought.
Well said! Gotta go, Idol's coming on.
