frankenstein rear end knock-off
- SELF INTRODUCTION: Former member of CBH....learning the ways to chop. Had a few bikes before....a few now...and lots more to come. Currently on a trike build, and a bike build. Thanks for having me back on board Dan. Hopefully I will do you guys proud!
Re: frankenstein rear end knock-off
more
- 16 resplined axles.jpg (99.73 KiB) Viewed 9074 times
- 17 resplined axle end.jpg (99.87 KiB) Viewed 9074 times
- 18 diff bolted together.jpg (90.59 KiB) Viewed 9074 times
- 19.jpg (102.4 KiB) Viewed 9074 times
- 20.jpg (106.25 KiB) Viewed 9074 times
more
- 21.jpg (104.44 KiB) Viewed 9074 times
- 22.jpg (106.33 KiB) Viewed 9074 times
- 23.jpg (95.36 KiB) Viewed 9074 times
- 24 old flange turned down.jpg (103.92 KiB) Viewed 9074 times
- Dana 30 modified differential.jpg (98.24 KiB) Viewed 9074 times
more stuff
- P-10-001-01_(Sheet_4_of_4)[1].pdf
- (251.94 KiB) Downloaded 343 times
- P-10-001-01_(Sheet_3_of_4).pdf
- (266.9 KiB) Downloaded 371 times
- P-10-001-01_(Sheet_2_of_4).pdf
- (304.84 KiB) Downloaded 343 times
- P-10-001-01_(Sheet_1_of_4).pdf
- (385.55 KiB) Downloaded 346 times
Hahaha now you guys have everything I have on it....the rest is just eyeballing and winging it
I amnot sure if this will help with the sprocket sizes!!???
http://www.sprocketcalculator.com/
Deifferential to tire gear ratios!!
http://www.offroaders.com/tech/gear-ratio-chart.htm
Man that looks good....wish I had the time to learn cad skills!
the 5/16 bolt holes for the sprocket and disc should be a max of 7/8" at the very deepest. That still gives you an eighth of an inch before you break through the wall into the cavity (which still won't be a deal breaker even if you make that mistake)
The 45 degree bevel is just for aesthetics and weight but is maybe 1/2"
The carrier bearing surfaces are identical on each end so the bore is machined to 1.627 dia x .865 deep
bolt pattern that bolts both halves together is whatever is standard on the dana 30 (can't remember that though)
lots of this stuff was just off the top of my head by looking at pics and then figuring out how to do it. Kinda like we all do with our bikes
Here is the finshed frankin rip dxf!!
Anybody see anything wrong???
I will try to find a cloud server to post it up on if not!!
Anybody need any diamensions I can diamension it out if you ain't got CAD!!
I use Draftsight it is FREE!!
http://www.3ds.com/products-services/dr ... /overview/
I just relised I did not fix the 7/8 bolt holes I got that fixed now!!!
Man Thank You So Much for This!!!
Did I overlook it or do you or can you please make a sketch of the axle tube outer pieces??
I will find a hosting site for the dxf files I hope???? Most only support pic and video uploads???
Hi Customize IT....the 5/16 bolt holes that are 7/7" long are fully threaded.
The only thing ppl have to realize though is that the left side cavity I do not have the dimensions on as I simply used the dana 30 carrier to obtain them while I was turning the pc. I did not keep those dimensions. Though it would be easy to figure out if you had a carrier on hand to measure.
Nope no sketch of the axle outer pcs...i just freehanded them as I went.
here are the spacer rods done.
12 inches between shoulders, 1.250 aluminum.
overall length of 12.230
drilled and tapped an inch deep on each end with 1/2" 13tpi
- 25 spacer rods.jpg (38.36 KiB) Viewed 9058 times
