It was presented to me that some of the guys and gals building springers may not have access to a machine shop to have parts made. One section that was of great concern was the spring retainers. People emailed us about not liking the price on the stuff that was out there and what could i come up with....well here is my answer.
there is an eight pc retainer set made out of a durable plastic that will be $45.00 shipped in a flat rate box anywhere in the USA. You can buy the proper bushing from mcmaster car or we can provide the set of 2 to you. These parts will allow you to pinch the top and bottom of each of the top and bottom springs and keep them aligned with the spring rod. the fact that the bush is plastic and the retainers are plastic will help the spring rods not take a "set" as the metal system usually does.
Some of the other cool parts we have are plastic trees and spring perches, and lower clevis setups in plastic. These parts are made with the mind set that if you build a springer you will be ahead of the game with these patterns to measure your stuff out properly. It is made with the mindset of a garage builder going into low production springers. We also have a mock up jig that you will set the Rake and neck height and you will see what your springer should measure out and look like.
any questions please post. Also post your thoughts on what we are doing so we can help you guys get to building.
CBH Springer parts
Re: CBH Springer parts
Thats cool man....hope you guys sell a shit load of them.
- gww25
- Site Grandaddy
By the way this is high impact plastic and should outlast the more conventional brass or aluminum retainers. The plastic mockup parts will make work far easier for you guys running small production or prototyping operations.
Would you need to buy 2 for a springer, or is this kit for bothe springs?
Also...Is this the 1st item in the CBH catalog?
Will the plastic threads hold the spring tension?
I never cared much for springers, so don't know much about them. I assume the threads hold tension.
rudy,
we hope to have all kit parts for our blueprints. We are also looking into kits for prototype jigs for setup and small run production and tool kits (needed reamers drill bits holesaws and the like) to help making the parts easier.
Bob,
the threads were just part of an original prototype. The plastic part is just a retainer. You would add a washer and an acorn nut or the like.
another questions or suggestion on these parts?
Bob,
I like the kit idea, for someone new to this, it's pretty time consuming to find out..
1. What you need for tools
2. Where to find them
3. Minor jig parts and fixtures
Thats after you decide on the style of bike you want to build, and find plans, or do them yourself, which
leads to a whole different quest.
How bout a flowchart? Don't remember ever seeing one of those, but break down the whole process, step by step,
on what someone needs to do to build their ride.
Maybe there is already something like that, and I just don't know about it.
Is that too much? I mean major steps, after you choose the type of bike you want to build.
Do you build a frame, or buy one? Use a jig, or not?
Link the steps in a flowchart to articles for detailed info.
Sounds like a huge amount of work. Probably not worth it, unless there was a market.
Just some rambling thoughts.
