new toys
new toys
been busy as hell lately workin to buy some new toys picked up a edwards iron worker with a bunch of punch and dies and a bender dam nice machine it cuts 1/2 inch plate 12 inches wide and bends it with almost no effort . then i just got an old south bend lathe looks to need some work but nothing i shouldnt be able to get going . dont know much about it yet i cant read the plate where the model number is too badly banged up . should be way better than my harbor freight as much as i try and beef it up it still has lots of flex at the tool post dont think ill have that problem with the south bend and the south bend has a left hand thread position so i should be able to turn going away from the chuck as well . i think i look foreward to rebuilding it as much as makeing stuff with it . i still need to get back to the bike projects too just not enough hours in the day to play
Re: new toys
You lucky dog! New toys is fun.
Try to restrain yourself from punching, bending and shearing all the material in sight.
Re: new toys
i tried for a bout 30 seconds couldnt resist
Re: new toys
got the lathe running today it runs real smoothe and quiet it is definatly nice to be able cut the face on auto . got some cleaning and some stuck knobs to free up but it already cuts way better than the harbor freight looks like ill have a harbor freight for sale soon
Re: new toys
Sweet! I dig that kind of stuff
Re: new toys
got all the rust and crust off the lathe mostly in primer waiting for the paint to show up got everything free and working properly got to find a new screw for the cross slide way too much backlash for my taste and probably a new chuck so i can clamp larger things from the outside but everything else is well within tollerence unbelieveable for a 60 plus year old machine . but then again thats when things were made to last . i ll post some pics this weekend
Re: new toys
Double check the screw and nut when you take it apart. The nut is designed to wear. The screw may be OK.
Re: new toys
www.lindsaybks.com used to sell repair and maintenance manuals for south bend lathes that were the last word on the subject of bringingan old , abused piece of equipment back to a useable state of precision !!
Re: new toys
rudog wrote:Double check the screw and nut when you take it apart. The nut is designed to wear. The screw may be OK.
the end of the screw is broke off where the crank handle is someone welded it back on they did a good job but it hasno indicator anymore . i have been on e bay there are a couple just scrapein some cash together now but ya there is some wear on the nut too . the compound has about 3 thousands backlash im thinking thats real good for a machine this old.im thinkin i can live with thatone for a lil while
Re: new toys
partial primer gettin ready for paint you can see where someone welded the cross slide screw togetherto the handle they used a nut and washers for the space where the indicator was gotta replace theese parts everything else seems to be fine cant wait for the paint to get here . i orderd rustolem hamertone dark green ill probably hit it with some ppg clear when its done should make it much easier to keep it clean . i plan to use the hell outa this thing
Re: new toys
coming up nice
Re: new toys
thanks max. today took the apron apart to get everything cleaned up and primed . was about ten pounds of crud in all the gears everything cleaned up nice. supriseingly everything was in great shape considering all the crud built up on everything . pain in the ass puting the clutch back together but everything went well should have more pics monday
Re: new toys
Sometimes all that crud is caked with oil and grease and actually helps. Sometimes not so much.
Re: new toys
there was way too many metal shaveings in it too plus the oil holes were plugged but i did think at first it was just heavy grease and was going to leave it but found the shaveings after the first coat of primer had to strip it down
Re: new toys
Nice dude...way to resurrect an old work horse...Cleaned up good.I assume you keeping them at work?What are you gonna do with all your shit if you ever leave there.....?
