Fixtures for welding tables
In my work, frequently I spend time around pipe welders and fitters. I've seen some very useful site-built fixtures fabbed with whatever materials were on hand.
I've started taking pix of some of them, thinking I could use the ideas to fab something for my own table. These usually look look different from each other because
of using different materials, but the features are generally the same for each one.
Normally they are adjustable on 2 planes, or axis if you prefer. They also allow 360 degree rotation on one axis, and can be clamped or fixed in place.
I have a series of pictures of 3 different fixtures (A,B & C), and a couple of pix of a tool and part holder (D) for a table.
I'll post these as time allows.
Re: Fixtures for welding tables
Weld FixtureA1.jpg (165.52 KiB) Viewed 19906 times
Weld FixtureA2.jpg (170.12 KiB) Viewed 19906 times
Weld FixtureA3.jpg (192.1 KiB) Viewed 19906 times
Weld FixtureA4.jpg (178.68 KiB) Viewed 19906 times
Weld FixtureA5.jpg (169.13 KiB) Viewed 19906 times
On the fixture above you can see the swivel, or hinge, and a level adjuster with locknut on the other end. There is also a clamp above the hinge area, to clamp the pipe insert.
The level adjuster is made from all thread welded to the base.
The steel plate on the bottom is called a strongback, used to stiffen the fixture.
The 3rd pic shows the turntable inserted into the fixture and clamped.
In the 5th pic, you can see a pipe extending below the corner of the table. The fixture has a smaller pipe inserted into that and is clamped in place while working, or can be removed.
The small vertical tube was tack welded for a temporary rod holder.
Edit: forgot to mention the work holder inserted into the fixture. Built on-site, it is welded to a pipe which has been sized to fit into the fixture, and can be rotated and clamped to allow easy access for welding a part. The flat plate has slotted holes for easy bolt up of the work piece.
Here is a similar style, built with different materials. This one is welded to the table and uses bearings for the turntable rotation. Bearings are mounted to a plate which is hinged and has a level adjuster.
Weld FixtureB1.jpg (141.01 KiB) Viewed 19884 times
Weld FixtureB2.jpg (134.3 KiB) Viewed 19884 times
Weld FixtureB3.jpg (143.69 KiB) Viewed 19884 times
Weld FixtureB4.jpg (126.68 KiB) Viewed 19884 times
Weld FixtureB5.jpg (127.25 KiB) Viewed 19884 times
Same with this 3rd style, different materials, same basic features...
Weld FixtureC1.jpg (177.63 KiB) Viewed 19884 times
Weld FixtureC2.jpg (152.18 KiB) Viewed 19884 times
Weld FixtureC3.jpg (158.19 KiB) Viewed 19884 times
Weld FixtureC4.jpg (138.64 KiB) Viewed 19884 times
Weld FixtureC5.jpg (114.65 KiB) Viewed 19884 times
This is a removable fixture for tools and materials. Fits into a hole in the table top, spins.
Weld FixtureD2.jpg (164.88 KiB) Viewed 19884 times
And this is an interesting way to cap a pipe or tube...
Weld FixtureD1.jpg (127.1 KiB) Viewed 19884 times
Fabricated tool stand to keep your multiple grinders handy...
tool stand-1.jpg (174.85 KiB) Viewed 19808 times
tool stand.jpg (188.93 KiB) Viewed 19808 times
Hi railroad bob, very cool fixtures man. Have a great christmas and happy, safe new year. :D :obscene-drinkingcheers:
