A question about top rails of the CBH and CSC frame jig
justin caise
SELF INTRODUCTION: Seemingly still just a wannabe, as I've not actually built a chopper yet. But I know what I'm doing. I'm startin slow, studying, tooling up, and thinking about it properly - someone here once said "The important thing about finishing your first build is to not let your ambitions exceed your abilities." I'm holdin my ambitions just a little ahead of my abilites so's I can stay motivated. Gary said the balance of time and money is key - So, I'm working that, too. Just reallly grateful to find that this incredible resource is still alive and accessible.
I'm hoping to actually connect with and make some friends here this time.
I'm in So NH repairing and riding the low buck jap junk for now... practicing, discovering my fav riding style, learning CAD, machining, designing and building tools. Lonely. I've got friends and family, and riding buds but no close chopper freaks to hold a torch. Aaaaand, I've said too much again....
Post by justin caise »
I have a question about purpose of the CBH and CSC frame jig top rails (the 1/2" by 2" flat stock which lays on top of the main rails of the jig)
Are they there to keep the rails straight and in line with the center line?
Can we do without them?
I'm using a heavier wall than normal for the main rails (.25" wall because it's what I've got) but I've noticed that even they aren't exactly straight and true. Flat stock on the top makes it even heavier and brings up the cost so I'd like to do without them, but not at the expense of precision.
What are peoples thoughts on this?
Your car should be old style
Your clothes rather new
Your chopper - a tasteful mix of the two.
Re: A question about top rails of the CBH and CSC frame jig
A jig can be a straight chalk line on the floor or made from wood.
So, build your jig however you want just make it striaght when done.
A tube is not always round or square as it is extruded when made and rolled by a machine. That is the one reason fo the top 1/2 plates to give a more parrellel suface.
No you do not have to have them!
go thru this thread and you will see some of the many forms jigs can take.
http://www.choppercompendium.com/ccforu ... f=22&t=227
