Page 3 of 4
Re: rudog#1
Posted: Mon Mar 05, 2012 11:38 pm
by rudog
Allrighty then, enough work...back to business. Hans, stop posting those awesome frames. Your having a bad influence on me.
I wanted to see what it looked like with the axle pushed back an inch. The tape slipped and I moved it back 2" (thanx Hans). I've tried moving it forward again, but I can't hold the wrench without a shooting pain in my neck.
- fab23.JPG (50.14 KiB) Viewed 8649 times
I hope to put the battery behind the tranny. The extra room may be good. The seat is about as low as I can get it. It's also not as level as I planned, so the support in the back may be lacking.
Re: rudog#1
Posted: Tue Mar 06, 2012 11:26 am
by yona
Your making me work here ... after enlarging, if you can tuck the front of that spring under the top tube , the support under the spring will determine the position.... I can fix the seat for more support across the back !
Re: rudog#1
Posted: Tue Mar 06, 2012 2:23 pm
by jonester123
Re: rudog#1
Posted: Tue Mar 06, 2012 5:44 pm
by rudog
Thanx, Jones.
YONA, the seat is not as bad as it looks. The angle doesn't show the sweep properly, but you were right...I should have put more sweep in the back. I'm glad It's not covered now. I may wait to ride it and see.
Re: rudog#1
Posted: Fri Mar 16, 2012 10:00 pm
by rudog
Enough with the BS...Got most of the top welds done. I envy you guys with rotating jigs. Next I'll set the gooseneck brace and then the motor mounts. I'll prolly add the gusset last, just to get some pics without one.
- fab30.JPG (41.84 KiB) Viewed 8593 times
Re: rudog#1
Posted: Thu Apr 05, 2012 12:00 pm
by rudog
This is for YONA. After making several compromises in looks. I mocked-up the spring perch. I couldn't weld wood good enough to suite...so I'm wittling it out of steel. It's a thight fit, but if anything breaks, the frame will hold the parts (and me) in place.
- MockUp49.JPG (20.52 KiB) Viewed 8577 times
I really dont want the seat modified much. I've spent so much time thinking of what the profile looked like. I never caught this shot before. Me likey.
- MockUp48.JPG (59.05 KiB) Viewed 8577 times
Re: rudog#1
Posted: Fri Apr 06, 2012 3:01 pm
Real nice job on the frame. I'm not clear on the seat spring mounting yet, but we will see that as it develops.
Re: rudog#1
Posted: Fri Apr 06, 2012 9:04 pm
by rudog
It's a simple perch welded to the seat post. The top clamp is held with 2 cap screwes from the bottom.
- MockUp52.JPG (17.24 KiB) Viewed 8559 times
Re: rudog#1
Posted: Fri Apr 06, 2012 9:54 pm
Clean mount you came up with man.
Re: rudog#1
Posted: Sat Apr 07, 2012 3:47 am
Agreed, very clean
Re: rudog#1
Posted: Sat Apr 07, 2012 12:06 pm
by rudog
Thanx, guys. The pic doesn't do it justice, and I'm not into bling guards and covers. Black powdercoat should blend it nicely.
As best I can tell, that should be the last part of the frame build. It still needs the neck gusset and tranny plate, but those are still a while away. I've decided to take Easter weekend off to regroup. So far what's taken me months, should only take weeks with experience. Building your 1st bike, like life, is a journey. I've enjoyed this journey.
Happy Easter to all!!!
Re: rudog#1
Posted: Sat Apr 07, 2012 1:52 pm
by rudog
This is the picture this thread was waiting for.
- MockUp53.JPG (28.31 KiB) Viewed 8545 times
Re: rudog#1
Posted: Mon Apr 09, 2012 10:27 pm
by yona
looking good, Ru......we need to get some leather on that seat ... ; ) Been busy learning to build a cnc router for aluminum.....I will build those fork legs if it kills me..... using 12" I-beam for the X, maybe 8020 for the Y and 6061 plate, acme thread and skate bearing carriages for the Z...... almost like a MechMate !
Re: rudog#1
Posted: Mon Apr 09, 2012 10:56 pm
by rudog
Don't let me stand in the way of your dream....but...I told you I could do that for you. Although, my lead times are to die for. I still got your e-wheel. Now that I remembered...
Re: rudog#1
Posted: Wed Apr 11, 2012 12:15 am
by yona
Was thinking you would send it with the seat....!
