Diamond Frames
Re: Diamond Frames
I suspect that the twisted stock is purchased that way. Both twists go the same direction.
Maybe its just me, but if I went to the trouble of twisting some square stock, I would make some going in each direction,
and have symmetrical twist each side.
Re: Diamond Frames
Thanks guys, some great comments and some even better ideas, I do like that springer and yes I would want the twist going in opposite directions..... :think:
Just for the record, I already have a plan for the FZ750 project build but I am still thinking through the diamond frame build......the frame has mounts for a GS550 but I've ben looking at a GS750 motor....but then again I could easily change the motor mounts........ :whistle:
I'm feeling better now so have been doing some trick machining (like yer do) and hopefully I'll get my bike table modifications finished before Christmas.....then I'll be going full on with the FZ750 build..... :banana-dance:
Tim B 1640
SELF INTRODUCTION: well i'm just reregistering from the club before but i'm a union laborer in boston ma and i'm working on a sporty build with an S&S 100" sporty motor and this is my first build. i built my frame with the help of tigman and i will be running a 250 rear tire with a piece of 6" copper pipe for my oil tank as well as a springer front end
Re: Diamond Frames
Post by Tim B 1640 »
Maz what did you use for a die to bend up that frame ? that's pretty cool!
Re: Diamond Frames
I don't know who built that Springer but something is horribly wrong with it. Notice that both the rebound and compression springs are both at almost complete compression with no room left between the coils for any 'spring' action to take place. I've seen a few like this in some of the magazines. Looks like the builder was way off on the length of his spring rods or the springs were way to long for the rods they used. I'm totally amazed when I see stuff like this in the marketplace. Cool idea but poor execution. A custom Springer should at least provide a little suspension.
Re: Diamond Frames
gww25 wrote:I don't know who built that Springer but something is horribly wrong with it. Notice that both the rebound and compression springs are both at almost complete compression with no room left between the coils for any 'spring' action to take place. I've seen a few like this in some of the magazines. Looks like the builder was way off on the length of his spring rods or the springs were way to long for the rods they used. I'm totally amazed when I see stuff like this in the marketplace. Cool idea but poor execution. A custom Springer should at least provide a little suspension.
I really should look more closely at some of these pics...you are absolutely right Gary....... hopefully not a mistake any of the guys on here would make........ :pray:
triker_chewie
SELF INTRODUCTION: chewie from perth western australia. i'm triking up a vw and chopping up a yamaha and repairing broken tools. jeez 200 characters is a lot. GOT A WIFE AND KIDS SPENDING ALL MY PLAY MOEY ON FOOD AND CLOTHES AND OTHER USELESS SHIT sorry bout the caps put them on for the code thing
Re: Diamond Frames
Post by triker_chewie »
its a Jeri's springer
Re: Diamond Frames
Well that explains a lot. many Springer builders use a set of de-tempered springs during mockups and on displays so they can take the forks apart without using a spring compressor. To me however those don't look like mockup springs.
