Here's a quick run down of where I started. I scored a couple Honda XR Dirt Bikes on the cheap so I thought "why not?" I'll chop one up. So currently I'm looking to figure out a way to use the existing axle plates & brake stop mechanism on the swing arm and tie them into a hard tail. If you are familiar with these bikes they don't have a single backbone down tube. The backbone stops just behind the gas tank and splits into two down tubes that mate with the bottom of the frame (essentially the front portion of the frame is like a cage around the engine). A quick google search for a Honda XR200,250, or 350 and you will see what I'm working with.
All of that being said most pre-fab hard tails and even custom built stuff I've seen use solid flat steel axle plates 99.9% of the time. (aside from some of the "boxed in" plates). The swing arm on the XR's is a little different, where as the axle plates are flat steel with a box steel plug that's just jammed into the square stock steel swing arm and welded together. Or at least that's what it looks like to me. So before I get to the real crazy question; My first question is would there be any potential problems by just welding the frame tubes on the top and bottom of the square steel swing arm and then cutting the swing arm away and putting in some gussets? I know that with the flat axle plates the tubes are generally "slotted" and pushed over the plate. What's the extra mile I could walk to ensure this is a safe connection? Below is a quick diagram I whipped up that will hopefully make sense.
(Diagram is not accurate dimensions just for visual aid)
REAL Crazy question:
Could I just extend the square swing arm steel back into the frame where it originally pivoted, run an additional bottom tube, ladder bar brace between the square tube and the new bottom tube, and then extend the backbone down to a cross member? Could I do that and eliminate the seat stay down tubes? If it would be a death trap waiting to happen from an engineering stand point I'll pass....but only having lower tubes in the rear would totally look bitching.... diagram below. Thanks in advance for any advise and input!
