Page 1 of 3
Welder
Posted: Mon Feb 20, 2012 11:56 pm
by James77
What kind of welder would I need in bike building? Mig, Arc, or...? For stuff like brackets and so on?
Re: Welder
Posted: Tue Feb 21, 2012 10:18 am
any welding process will work but mig is the easiest to learn and the smaller machines arent that expensive anymore
Re: Welder
Posted: Tue Feb 21, 2012 12:25 pm
by James77
curt wrote:any welding process will work but mig is the easiest to learn and the smaller machines arent that expensive anymore
So, I won't need a real powerful welder?
Re: Welder
Posted: Tue Feb 21, 2012 12:29 pm
by jonester123
Hi there, welcome to the forum. Curt is right all welding process will work more or less, get yourself a 180amp-200amp welder mig or tig with gas bottles for cleaner welds. Takes alot of practice to get good descent welds in all materials. Good luck.
![biggrin :D](./images/smilies/icon_e_biggrin.gif)
Re: Welder
Posted: Tue Feb 21, 2012 2:20 pm
by James77
jonester123 wrote:Hi there, welcome to the forum. Curt is right all welding process will work more or less, get yourself a 180amp-200amp welder mig or tig with gas bottles for cleaner welds. Takes alot of practice to get good descent welds in all materials. Good luck.
Thanks for the help guys. I was thinking about this welder. Problem is, I've heard bad things about Harbor Freight tools. Looks like a good welder, but I don't know.
http://www.harborfreight.com/120-amp-23 ... 97503.html
Re: Welder
Posted: Tue Feb 21, 2012 3:09 pm
by jonester123
I wouldnt waste your money on that welder, if you are going to do fabrication work and welding on frame tubeing and thick plate materials then you need to pay for a descent welder that is capable of welding that size materials. Look for a lincoln or miller mig welder of atleast 140amp- 200amp, they cost around $500.00 and up for a quality welder, it is always better to buy bigger so you have the power to weld thicker materials, and make sure you have the power to run them right.
Re: Welder
Posted: Tue Feb 21, 2012 3:11 pm
by gearhead1951
Harbor Freight mig welders arent bad , in fact they held up in a comparison test against 3 other welders that cost more to buy as a good tool for the money !!
Re: Welder
Posted: Tue Feb 21, 2012 4:13 pm
It's a crap shoot at best buying tools there.May work, but what happens when it needs parts.Id save & buy from a reputable manufacturer..... ie Lincoln, Miller to name a couple.
Re: Welder
Posted: Tue Feb 21, 2012 4:25 pm
by James77
Thanks everyone! I've got a buddy that has a mig welder....maybe I can get him to weld what I need. We have a Tractor Supply store here too....they sale Hobart welders.....I can save for one of those I guess.
Re: Welder
Posted: Tue Feb 21, 2012 4:56 pm
Hobart is a reputable brand in business for many years. For a purchase that will hopefully be a longtime tool, you should do some research
on several things.
Learn the major differences in the welding processes, not difficult to do. You have a friend who welds, he can tell you in a few minutes, and show you examples.
Cost for purchase, use of power, consummables, accessories
Power output, features, adjustable settings, ease of set-up.
The main thing to consider is whether you actually need a welder. One time project, possibly not.
Gaining knowlege is never a waste of time.
Re: Welder
Posted: Tue Feb 21, 2012 6:11 pm
check with your local welding supply house sometimes you can pick up a used machine that they have worked on or refurbished or someone traded up for a bigger welder usually you can get a much bigger machine than you thought that has many years use left especially for a home shop at a reasonable price
Re: Welder
Posted: Tue Feb 21, 2012 11:05 pm
by Dan.in.Can
think about what you want it for now, then think about what you might want to use it for a year from now. you don't want to go cheap and have to upgrade any time soon, there's nothing worse than paying for something twice. i like lincon cause thats what i'm used to, a lincoln 140 will handle anything your likely to be doing on a bike, my brother has one and thinks its great, it also plugs into a regular 120v outlet with a 20amp breaker. i run a lincoln 180, and would recomend it, can't imagine needing anything bigger for hobby use. but thats just my opinion
Re: Welder
Posted: Tue Feb 21, 2012 11:20 pm
by James77
Dan.in.Can wrote:think about what you want it for now, then think about what you might want to use it for a year from now. you don't want to go cheap and have to upgrade any time soon, there's nothing worse than paying for something twice. i like lincon cause thats what i'm used to, a lincoln 140 will handle anything your likely to be doing on a bike, my brother has one and thinks its great, it also plugs into a regular 120v outlet with a 20amp breaker. i run a lincoln 180, and would recomend it, can't imagine needing anything bigger for hobby use. but thats just my opinion
Well, the only thing I'd probably use it on is a bike, but there''s some stuff I'd like to do for our church too! I'll check out those Lincoln 180's!
Re: Welder
Posted: Thu Feb 23, 2012 4:12 am
by Maz
Don't waste your hard earned cash on a cheap welder, a good one will last you years and produce more consistent and better results...also get a good welding helmet etc.....
![Mazintheshed001.jpg](./download/file.php?id=959&sid=34abf022413e566d1662c9c098f965e1)
- Mazintheshed001.jpg (44.14 KiB) Viewed 10169 times
Re: Welder
Posted: Thu Feb 23, 2012 11:48 am
im thinking welding with those exposed might be a lil painful but id like to watch
![watching :popcorn:](./images/smilies/lurker.gif)
