quick spring compresser for springers
heres a quickly thrown together spring compresser its just some leftover scrap pieces of 1 inch tube and some 2 1/2 inch x 1/2 inch plate and 2 3/4 inch threaded rod and 4 nuts . i welded a nut on one side of each threaded rod then cut the tube till i had 4 pieces 2 1/2 inches long i cut the flat bar to 6 inches long and welded the tube to each side of both flat bars let it cool so i could handle it and it worked fine the only thing i would change if i was to build another i would use 1 1/4 inch tube instead of the 1 inch . when i was tightening it it would bend the rod a little because i was doing it myself i could only tighten one side at a time with the tube being a tight fit there was no room for the uneven ness of going back and forth so a little biger tube would be ideal i think . but it was totaly free ten minutes to build and did the job
Re: quick spring compresser for springers
Hi curt , very cool man. I was going to make one also for my springer build so i will follow how you did yours.
I would allow a bit more clearance for the long studs/bolts so they don't bind up quite so easily, otherwise its darn perfect
thanks hope it helps lots better than buying one for 50 bucks
ya thats y i would change to the 1 1/4 tube instead of the 3/4Maz wrote:I would allow a bit more clearance for the long studs/bolts so they don't bind up quite so easily, otherwise its darn perfect![]()
that would do it for sure - I really like the simple design of this tool - easy to make and easy to use
was real easy for me by myself
that is the sign of a well designed piece of equipment
I'll be making one for myself when I start my diamond springer build....
dude, you're gonna be so mad. i made a compressor pretty much like you did, and then i was at Tomo's place when he needed a set of springs compressed. i took a minute to talk to another friend of ours and when i turned around, he already had it apart. when i asked him how he did it, he pointed to his ratcheting tie-down straps. i felt like a total idiot.
looks like you did a great job on it though.
i thought about that but after reading garys article about doing it i didnt think it would hold up to the pressure oh well
just goes to show some folks are more resourceful than the rest of us
Respect to Tomo
no doubt theres always a beter way
dan i was watchin a rerun of biker buildoff with indian larry and mondo of denver choppers and they used a rachet strap on mondos assembly they only showed it fast but i did catch it
maybe I won't ditch that old oil-stained ratchet strap after all.......
