"pig nose" conversion
There is a cone cover panhead on ppg 22 of Januarys issue of Back Street Heroes that has had the cone replaced with a cover that sports an old style " slab side" distributor !
The editorial on the bike calls it a "pig nose" conversion but try as I might I caint find any thing on the web or anywhere else by that name , Does anyone have anything on this thing ??
Re: "pig nose" conversion
Can ya post a pic? Doesn't sound like anything I've ever heard of, at least by that name.
I think S&S makes a case set that is the early pan "slab-side" with electronic ignition where the distributor would normally be, but has an alternator left side.
- Fat Mike
- SELF INTRODUCTION: Just drooping in..the more the better.
Been riding 45 years, everything from a Sears and rare back mo-ped, Harley's.
Right now riding and building trikes.
Don't know what else to say.************************************************************************************************************************************************************************************************************** - Location: Retired (house hubby) older than dirt
This what ya a talkin' about???
Cone, flat side, generator.
I've never seen one with a setup for a dist.
NSFM
NSFM
- 2011_11010009.JPG (106.26 KiB) Viewed 9475 times
If it has two wheels---trike it.
I got no way to post the pic just now , but if you go to a new stand that carries the mag it is in Back Street Heroes as I said at the begining !
It has no other alteration but for the right side cover being replaced with a "form fitting" plate that allows what appears to be a stock HD distributor to engage a camshaft driven gear to operate it ! Looking at it I understand the "Pig Nose" description !
I think these might be the you are referring to......but I have no idea how they happen to be on here The text says its a Panhead with Shovel cases......gearhead1951 wrote:I got no way to post the pic just now , but if you go to a new stand that carries the mag it is in Back Street Heroes as I said at the begining !
Yeah , thats it !! That is a cone cover bottom end with a conversion to the earlier style distributor setup !!
Never saw or even heard tell of such a thing before !!
- sleepyonthree
not sure if these are anywhere close, from evilbay
- pig snout 2.jpg (4.65 KiB) Viewed 9438 times
- pig snout 1.jpg (2.65 KiB) Viewed 9438 times
- Fat Mike
I do a lot of looking around at swap meets ets...woooooooooo, neve seen and animal like that.
Woops hold it.....not the same motors...if ya look close..
The center pic is a true cone lower, not generator. That looks like the distributor is run off a gear where the points (sending unit etc.used to go).
The bottom pic is a flatside (slab side) where the distributor really goes on one.
The top pic...ya got me..can't see it good enough.
NSFM
NSFM
Ahhh Mike , I am sorry to tell you that all three of those pics are the same bike from the magazine article I referenced !
The "pig nose"reference seems to apply in the top photo, you can see a resemblance in the part that is below the carb.
In the center pic, you see it from the side, extending forward from the carb, but below center of the air cleaner.
I don't think the pig nose caption refers to the cases, but without reading the text, its hard to tell.
- SELF INTRODUCTION: dan. my names john or jbfrmca on most boards . i was on the old board(not very much i'm afraid) been messing with bikes my whole life. still want to learn as much as i can while i can. thanks in advance. later john.
i think that is a cone for a magneato with a slabside timer on it. cool looking for sure.
- yona
jbfrmca wrote:i think that is a cone for a magneato with a slabside timer on it. cool looking for sure.
Definately a mag cover for a shovel or evo .....i have one for a shovel somewhere , but never got that mag Weyland promised ...LOL
I found both "Morris" and "Joe Hunt" mag conversions to a FB mag , similar to the cover on the bike in question but no cigar , They just look like a cone cover modified to run a mag but the "pig nose" is clearly cast special for the purpose !!
- yona
Joe Hunt cast cover for a Mag....Vertical.....
Joe Hunt Cast cover for a Mag....Horizontal....
Morris Cast cover for a Mag..... M-5 Vert.....
Cars is a chromed S&S like I found on the old Harman Shovel ...
but carb exited on the left side .... Cool
- SELF INTRODUCTION: I've been building and working on motorcycles for over 35 years, I own a bike shop and I am a tool & die maker. I'm into old motorcycles more than new ones, and am also into old machine tools. I mostly build my bike from old parts or parts that I make.
That looks like an old Morris, magneto cam cover from the '70s or early '80s with a gen.motor timer in it.
Mark.
