custom length pushrods
Like it says above.
Found this link in a DIY section, making pushrods to your custom length...
http://aircooledtech.com/custom_push_rods/
Then went to the supplier and found this,
http://www.cbperformance.com/catalog.as ... tID=1243is link...
Chromoly with dimensions. I didn't compare to HD rods. but if you don't like adjustable rods, you might give these consideration.
8 to a set for $155, enough for 2 HD evo motors. Some high performance motors are very hard on adjustable pushrods.
I know I've bent some in the past.
Re: custom length pushrods
Thanks R'Bob.
This......I can use immediately.
http://aircooledtech.com/tools-on-the-c ... ing_beads/
andy....
hansgoudzwaard wrote:Thanks R'Bob.
You might do research on this. It sounds good, but I've seen posts on the motocy forum on craigslist
that were not favorable.
The concept sounds reasonable tho.
RRB is easier..... :lol:
