Chain tensiorer
lakesmod
SELF INTRODUCTION: I'm a 60ish owner of a late '84 model H-D Sportster. I live on Taylor Bay on the Key Peninsula coast of Puget Sound in Washington State. I've had the bike about 1-1/2 years. Changed drag bars to apes. I'm in the process of lowering the rear about 4". I don't like stock & I enjoy modifying. Have had Honda's, Triumph's, Sportsters and Shovelheads.
Re: Chain tensiorer
Post by lakesmod »
Thanks but the material in question is on top of the aluminum swing arm.
lakesmod
Re: Chain tensiorer
Post by lakesmod »
Thanks,but the material in question is on top of the aluminum swing arm.
Re: Chain tensiorer
I see said the blind man.Im doing this on my Ipod.Didnt even see that till you pointed it out.Looks like its there to keep the chain from slapping the swingarm...Teflon maybe?
lakesmod
Re: Chain tensiorer
Post by lakesmod »
Thanks for sticking with me on this .
I think teflon would wear faster then UHMW.
https://en.wikipedia.org/wiki/Ultra-hig ... lyethylene
My problem is the chain has only about 1/2" before it will hit the top frame because I have lowered the bike about 4".
http://s210.photobucket.com/albums/bb166/lakesmod/
Re: Chain tensiorer
On a swingarm bike you need a tensioner with a lot more 'travel' than what most of us use on a rigid frame but most swingarm bikes don't need a tensioner to begin with so why is this an issue on your particular project? Are you planing on running a jackshaft for the bike or is there some other design element that requires the use of the tensioner? As a general rule the use of a chain tensioner on a chopper frame is because you're running a non-adjustable axle block or you have a clearance problem with the chain. On a swingarm frame you should not have any clearance problems and it's almost mandantory that you have adjustable axle blocks. Try to post some diagrams or photos of the particular issue or design element on your project and we can provide some better input.
lakesmod
Re: Chain tensiorer
Post by lakesmod »
I have lowered the rear about 4-5".The swing arm is now running at a angle putting the chain a 1/2" from frame at the bottom of the oil tank.
Take a look at the above address for photo bucket,A good picture is the 3rd row 4th picture from the left.
lakesmod
Re: Chain tensiorer
Post by lakesmod »
I should have said the chain is 1/2" from where the frame go's behind the oil tank.
Re: Chain tensiorer
I see the problem and it looks like a tensioner should keep the chain below the tank but I haven't looked at the specific geometry with repect to the chain for the full range of travel. It may be easier just to build a custom tank and chain guard. Nice work by the way of getting that bike lowered.
Re: Chain tensiorer
Someone here built a really nice yellow pro-street style chopper years ago, and used a chain tensioner.
I think his user name was Jacked800, or something like that.
Haven't seen any posts from him in years tho.
lakesmod
Re: Chain tensiorer
Post by lakesmod »
Thanks for the complement.
I have looked at McMaster-Car and Grainger web sites for a sprocket to make a idler.
They list there sprockets as #40-50-60,my chain is a 530. Dose 50=530?
Re: Chain tensiorer
lakesmod wrote:gww25
Not to answer Gary's question, but yes Ansi 50=Bike 530.
lakesmod
Re: Chain tensiorer
Post by lakesmod »
riceburner
SELF INTRODUCTION: I am a motorcycle repairman, artist, fabricator, machinist, welder, bender, fitter, eater, lover, fighter, I live in eastern denial. A man sought to see the Dali Lama he climbed the mountain to find he must spend 5 years in contemplation before he can see the Dali Lama, after 5 years past the man was taken to see the Dali Lama he asked him "what is the meaning of life?" the Dali Lama looked at the man, smiled and said "well my son, life is like a bean stalk, isnt it?"
Re: Chain tensiorer
Post by riceburner »
