General assembly question
When you build your bike...Do you use some kind of thread lock In addition to lock washers to secure your parts?
Re: General assembly question
I use a variety of methods to secure threads etc...on the girder forks I use grub screws (I think you guys call them set-screws) and on anything that is likely to vibrate loose I tend to use thread lock. For threads that don't get too hot I like to use nylocs and then fit a thread finisher (my own sylver bullets) which I thread lock into place.
On the rare occasions that I build a competition or ultra-high performance bike (or hotrod) then I cross drill the heads of the bolts and lock-wire them into place...... :think:
There are at least 3 types of Locktite threadlocker for different services.
And as Maz stated there are mechanical choices also.
One not usually mentioned is thread peening, which means slightly damaging a thread on a connection after installation,
but only slightly. This prevents a nut from easily backing off, and in fact, if done properly, a nut needs a fair amount of effort to be removed past the damaged area, but can still be removed.
This can be used in a remote location with no access to normal tools. A light tap with a hammer and a pointed tool on the thread closest to the nut does the job.
Not to be confused with "pinging", which is tapping a bolted connection to listen to the resulting sound. A ringing sound indicates a torqued connection, a dull thread indicates a loose connection. NOT used in vehicle work normally, where a torque wrench is preferred.
for me personally, i like to use nylock nuts where i can and then let the bike tell me what needs some thread locker. keep in mind that i try to go over almost every bolt and nut on the bike after *every* ride until i've ridden it enough to feel it has "settled in." even then, i am a stickler about maintaining my bikes.
i don't think you really need to over do the threadlocking compound. and it has no place on an engine or transmission at all. just my .02.
Thanks for the replys.... I'm curing some parts in the oven as I type this, so hopefully I'll be puttin some things together real soon.
monkeywrench202
SELF INTRODUCTION: I was a memeber on the old site, but couldnt log in here. I have a small shop where I do resto/ mods, build complete bikes (6 to date) ground ups. Been working @ Drive train specialists since 02 building custom automotive axles.
Post by monkeywrench202 »
In my world, lock-washers are an evil item. they split, break, fall out, and just are never reliable. Good thread-loc, and proper torque on all fasteners makes the difference. As stated, bolt-tightening sessions are a must for many rides.
One piece of advise - if using any type of stainless fasteners, make sure thatyou put something on the threads, no matter what. They love to gall up and lock up tighter than a pop-corn fart. Loc-tite, anti-sieze, greese, ect, never put a stainless fasteners together dry.
anything that has a vibration to it i use locktight be careful with the red though it can be a real pain to get back apart .if its somethin that needs to be serviced regularly use the blue
I just use nylon fishing line , stuck into the nut as it goes on and make nylocs out of all the nuts....works as good as blue loctite and easy to disassemble...
Hey.... That's a good idea.What lb.test line do you use?
joe49
SELF INTRODUCTION: Been on the CBH since 04 been on bikes since 68 'nuff said............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
Post by joe49 »
yona wrote:I just use nylon fishing line , stuck into the nut as it goes on and make nylocs out of all the nuts....works as good as blue loctite and easy to disassemble...
Ditto, has worked for me for the last 35 years.
Now I know what to do with that crap I find on the riverbank where some jerk left it birdnested in a bush.
