http://www.calculatoredge.com/english.htm#mechanical
This site has different sections, mechanical, structural, oil & gas, etc.
In the mechanical section, listed above, I noticed some calculations for leaf springs, but didn't look in depth.
Possibly useful for someone planning on building a leafer.
I was looking for ways to calculate and compare deflection of tubing and solid round steel to each other.
No time right now to dive in, but will post any pertinent info.
Here is a different site with a calculator for deflection of tubing.
http://easycalculation.com/mechanical/d ... -beams.php
Online Engineering Calculators
Re: Online Engineering Calculators
http://www.calculatoredge.com/civil%20e ... r/beam.htm
This one looks like it has good potential...
These would allow comparisons only if you use the same parameters for each calculation.
This is not a method to calculate the stresses on a fork leg. That would involve the use of complicated equations
and include much more info, like the fork angle, friction forces caused by traveling on a surface (would probably be a range, since the surface can be so different, ie, paved versus gravel or loose soil), lean agles, centrifugal force, and probably more I haven't thought of.
Point being, this is a way to see if tubing resists force better than solid round stock in a limited application.
joe49
- SELF INTRODUCTION: Been on the CBH since 04 been on bikes since 68 'nuff said............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
solid stock will always have a higher moment. The advantage of tubing is weight. For the best compromise tubing with a ID near .25 of the OD. Still heavy though.
Sounds reasonable... Is this info from a published source?joe49 wrote:solid stock will always have a higher moment. The advantage of tubing is weight. For the best compromise tubing with a ID near .25 of the OD. Still heavy though.
Northchop
- SELF INTRODUCTION: Started building choppers in '82, became a certified motorcycle mechanic in '88 from Fairview College in Alberta, got a 1st place trophy for a Santee softail long chop I built in '93 at World of Wheels in Calgary, rebuilding/refining my '74 Norton 850 rigid long chop now. In the bush, in a converted greenhouse, in NW Canada, 100 miles from Whitehorse.
Machinery's Handbook, #29 PDF:
http://dl.icdst.org/pdfs/files4/80364b0 ... 119ffc.pdf
Machinery's Handbook Pocket Companion
https://iem.ca/pdf/resources/Machinery% ... hinist.pdf
