Page 1 of 2
Chain tensiorer
Posted: Thu Feb 02, 2012 1:50 pm
by lakesmod
Has anybody made there own chain tensioner.
Pictures?
Re: Chain tensiorer
Posted: Thu Feb 02, 2012 7:19 pm
i remember some on the old bord maybe dan can get em for ya but i think he said it was fragmented so he might need time
Re: Chain tensiorer
Posted: Thu Feb 02, 2012 9:40 pm
by sleepyonthree
Picture from the old board of three tensioners, not sure of the thread it came from. Appears to used a modified
auto drive belt tensioner.
Serpentine belt tensioner from napa for a 1998 GMC Yukon showen. Doubt the plastic belt
pulley would hold up to a chain. The nub on the housing fits a hole to restrain the spring tension
and provide the tension factor.
Re: Chain tensiorer
Posted: Thu Feb 02, 2012 10:49 pm
by Maxthegardener
I had a load of links and picture and variations on the old board. I'll look.
Re: Chain tensiorer
Posted: Thu Feb 02, 2012 11:33 pm
I made this one.
![IMG_0012.JPG](./download/file.php?id=896&sid=c9b81fff963a721b7aebed04dbca8417)
- IMG_0012.JPG (39.44 KiB) Viewed 8113 times
Re: Chain tensiorer
Posted: Fri Feb 03, 2012 11:47 am
by lakesmod
Thanks for the replys.
Jeff L-Can you give me some details ,like what sprocket and bearing did you use?
Thanks, Fred
Re: Chain tensiorer
Posted: Fri Feb 03, 2012 12:46 pm
The sprocket is an industrial ider sprocket from tractor supply.I forget what size, but its same size as 530 chain.The bearing I got in a bin at the steel supply I go to.It was a little bigger than the bore in the sprocket, so I just opened it up to fit.
Re: Chain tensiorer
Posted: Fri Feb 03, 2012 1:17 pm
by yona
The Chevy tensioner and the sprocket ( Grainger's ) is the cheapest unless your time is not worth anything ......I have cut the Chevy one down to use on a lot of different cars and bikes....... they polish out nice also.....The junk yards are full of them, I buy them by the 5 gal bucket full...i get the one that are locked up and say I am getting them to melt down and cast stuff. they weight the bucket and charge me the going price of scrap ! i mounted one on my Mower deck , when the stock piece of crap broke ...cuts down on the slippage so the belts don't burn up as fast1
Re: Chain tensiorer
Posted: Fri Feb 03, 2012 3:36 pm
yona wrote: unless your time is not worth anything ..
...Wow dude...that is so far from the point of why you would Make a part rather than buy it.Considering what I make an hour at my job,everthing on my bike I could have probably bought cheaper than make.
Re: Chain tensiorer
Posted: Sat Feb 04, 2012 2:52 pm
by yona
Was not my point but what I make an hour is to help feed and care for my family....why cobble up something that can break and leave you on side of the road....? guess I am too old to what to be different...I just like stuff to work....Sorry for butting in ....
Re: Chain tensiorer
Posted: Sat Feb 04, 2012 3:19 pm
My appologies dude....sometimes its not easy to get someone point through a typed sentence.And fyi its not butting in....its called discusion.Different viewpoints are always good.especially when you dont agree with some...it makes you think.
Re: Chain tensiorer
Posted: Sat Feb 04, 2012 4:15 pm
by gearhead1951
If it is MY time , not out of my work day and not costing me any money then it is FREE !
And if it ends up sold then that is extra money I wasnt expecting !
Other wise the value is the fun I had creating and using what I have made from scrap and labor !
Re: Chain tensiorer
Posted: Sun Feb 05, 2012 3:23 pm
by Dan.in.Can
also what else would you do with spare time, for me i'd way rather be out in the shop tinkering away on a project, than sittin on the couch staring at the tube.
Re: Chain tensiorer
Posted: Mon Feb 20, 2012 11:19 am
by lakesmod
Can a fixed tensiorer be used with a swing arm or do I need a spring loaded one?
http://i191.photobucket.com/albums/z238 ... ral185.jpg
Anyone know what material is pictured in the above address? UHMW?
Thanks for your reply's.
Re: Chain tensiorer
Posted: Mon Feb 20, 2012 12:07 pm
With the movement of the swingarm & chain, Id go with spring loaded tensioner....From what I can see of the weld...Id say Aluminum.
