Building a Girder for my Honda Rebel 250
- SELF INTRODUCTION: I'm from Arkansas. Farm equipment mechanic. Love working on bikes with my 7yr old daughter. Single dad. Doing it all on my own. Good standing member over on the Honda rebel forum and TCU forum. My first chopper build was a Honda Rebel 250. Looking for a big brother to it. A Honda Rebel 450. I'm wanting to build a girder for the 250 and was told that this is the place to come for knowledge and help.
Re: Building a Girder for my Honda Rebel 250
Neck bearings arrived today also.
Tree's dropped off at lunch to have them drilled out to 15/16. Will work them out to size from there.
just curious, but how did you cut out the trees? do i feel a handheld grinder in there? i *am* quite partial to my grinder.
Yes sir. There is quite a bit of machine work in this. Trying to keep a balance between machine and me. That way I can say it's mine at the end of the day. Not all bought.budoka wrote:just curious, but how did you cut out the trees? do i feel a handheld grinder in there? i *am* quite partial to my grinder.
Tree almost done. Still have to drill for pinch bolt. But atleast now it is starting to look like something. LOL
Drilled for the pinch bolt.
Burn some wire friday.
Pivot points all tacked up.
Ready to go melt some steel.
may just be the pics but they look like cold welds. What welder are you using and what settings?
Melted a little steel a min ago.
It was set low when I tacked it. Welded sheet metal with it last.
She is set HOT now.
She is set HOT now.
still looks like the weld is sitting on top of the metal
may just be the pictures though.
You are right there was very little penatration. Almost none. But in the second picture I changed over to a different welder. The first machine had a board burnt up in it. Retacked and welded it with the hotter welder.krymis wrote:still looks like the weld is sitting on top of the metal
Starting to look like a tree now.
Got the stem fitted up, cut and now welded.
Painted the top tree to keep it from rusting for now.
Bottom tree still to hot.LOL
Mounted up the tree to check final measurements. Looks like I need to repaint the frame. Dang over spray. LOL
Bushings and washers arrived today. From McMaster-Carr.
Can you tell us what the Mc Master-Carr part numbers where on these since you have you billing slip right there?
Here you go.
1 6338K422 Sae 841 Bronze Flanged-sleeve Bearing, For 1/2" Shaft Diameter, 3/4" Od, 1/2" Length
2 5906K514 Sae 841 Solid Bronze Thrust Bearing, For 1/2" Shaft Diameter, 1" Od, 1/8" Thick
Optional bearing. I ordered both flanged and sleeved bearings.
1 6391K221 Sae 841 Bronze Sleeve Bearing, For 1/2" Shaft Diameter, 3/4" Od, 1/2" Length
