Hey,
Im building my springer and i have the trees cut out and pilot holes drilled. I have started to try to cut the 1.25" holes for the legs and im using a bi-metal holes saw and a drill press. Im finding it is realy sloooooow, almost not cutting. Is this normal? Should i be drilling on high speed with less torque or low speed with high torque? What lube should i use?
Any tips and info would be realy appreciated. At this rate, it seems like i will be standing at the drill press for days to do one hole!
Hole saw through metal
- Cycle-psycho
- SELF INTRODUCTION: I've loved motorcycles all my life! I have a 2006 Dyna that ive been customizing and I am now taking on the task of building a custom chopper!
I have some mechanical skills, but im not a professional mechanic or welder. Simply a home garage type of mechanic. - Location: BC, Canada
Cycle-psycho
2006 Dyna - with lots of goodies
2012 Ultima rigid - under construction
Cycle-psycho
Re: Hole saw through metal
http://www.chopperhandbook.com/springbuild.htm
scroll to Fig. 44-45.
The few times I've done this, I usually go pretty slow.
- gww25
- Site Grandaddy
Run the drill between 350-400 rpm. You can use almost any type of lub. Don't put much pressure on the press handle, let the saw do the work. It does go slow but it'll go through eventually.
lots of lube and easy on the pressure heat the saw too much and its junk its slow but works supriseingly well
- Cycle-psycho
Thanks guys.
I actually figured it out anyways, i was drilling way too quick. I slowed it right down and away she went!
Cycle-psycho
Cycle-psycho
