Maz's FZ750 Project
Re: Maz's FZ750 Project
Maz, MERRY CHRISTMAS and have a safe and great new year. :D :obscene-drinkingcheers:
Thanks Thomas - I decided after lunch that I would start into the top frame rails.....and of course me being me I just had to do something completely different for this project..... :doh:
Here I am modelling the latest in designer coveralls....
mazfz750 013.jpg (122.08 KiB) Viewed 10188 times
Here are the top rails after bending and the hand made template to check I calculated the bends right....
mazfz750 025.jpg (127.45 KiB) Viewed 10188 times
And here they are mocked up in place......
mazfz750 028.jpg (227.13 KiB) Viewed 10188 times
mazfz750 029.jpg (138.83 KiB) Viewed 10188 times
Tomorrow I'll check all the alignments and tack weld in place.....
Dual backbones, unusual and interesting...
Nice sweep to the bends. Was that hard to do?
msn1977
SELF INTRODUCTION: Mark Nienke, I have been a machinest and fabricator for over 30 years. Currently a home shop machinest and future bike builder (some day). Funnest project was my Maadi-Griffin 50 BMG which I built a few years ago. I have owned bikes on and off for the last 40 years. Built and sold two basket case sportsters. I currently own a 2008 Harley V-Rod.
Post by msn1977 »
Very nice Maz.
railroad bob wrote:Dual backbones, unusual and interesting...
Thanks Bob, the hardest part was working out the original design and then "mapping" the bends - it took a bit of time to work out the start points for each of the bends and to correctly calculate the radius of each one etc, but then I hand bent a piece of conduit to use as a checking template and having written it all down (I like to have a recipe) it took only a few minutes to mark out and bend the tubes. I have to say how impressed I have been with my Gottrikes monster bender, its very easy to use and makes doing repeat bends much easier than my old one....and yes I did get both rail the same!!!!!!
msn1977 wrote:Very nice Maz.
Thanks dude, I did say right at the start this was going to be a very "different" build and I'm sticking to it :snooty: :dance: :hand: :banana-dance:
More soon guys :obscene-drinkingcheers:
the suspense grows....
Do you remember what I told you 'bout a different way to gusset "diamond" frames ?
Is that little connector what you are going to use, or will you fit a piece, so that they don't have those big gaps on top and bottom /
yona wrote:Is that little connector what you are going to use, or will you fit a piece, so that they don't have those big gaps on top and bottom /
No its just an off-cut that was the right size to use for mocking up - I've already replaced it with a properly shaped piece.....I tend to use whatever is around for mocking up and then fabricate the proper pieces to fit exactly....I've also reshaped the lower rails at the front (tightened up the top bends) to get them to sit just how I want them..... :think: Next will be the split-plates for allowing the lower rails to detach for motor removal........ :shifty:
Next big jobs will be the gas tank and induction system, plus modify a rear fender ..... :think: ....oh yeah, and I need to make a new set of front forks :doh:
gearhead1951 wrote:Do you remember what I told you 'bout a different way to gusset "diamond" frames ?
I do remember but I don't have a copy of your drawing so please feel free to post it for everyone's benefit.....good ideas should always be shared :banana-dance:
Jeff L wrote:the suspense grows....
I hope you won't be disappointed with the final result Jeff :shifty:
i like that shape looks good on a woman and a bike
curt wrote:i like that shape looks good on a woman and a bike
Why thank you kind sir :obscene-drinkingcheers:
Bikesandfires
SELF INTRODUCTION: I'm a 54yo, fat, balding, bearded motorhead living in the hills of Eastern Ky. 35 year and counting firefighter, retired from 31 years as a crane operator, car nut from birth. I hope my free-mail account doesn't keep me from becoming a member of this message board. Current toys: 1966 Ford Fairlane 500, 1967 Sunbeam Tiger clone project, VW trike project, 18' Thundercraft boat.
Post by Bikesandfires »
Nice pattern on that garage floor Maz...Looks like it doesn't show dirt easily either...
Maz, now that is what i call a cool wicked looking frame design nice work. :D :popcorn: :obscene-drinkingcheers:
