Page 9 of 12
Posted: Wed Mar 27, 2013 6:57 am
by Russ
Looks like you're nearly there mate. Always liked this built can't wait to see it up and running.
Posted: Sat Mar 30, 2013 6:05 pm
I got a Package in the Mail the other Day.The Gears for my Kicker & Carb parts.Got the Tranny closed up, but the Carb Part was wrong.Have to search for another.Its a discontinued Part so may be hard to find.Went back to Work too.Got sent to a Paving Contractor so looks like night Work.That blows, but its work.
Posted: Tue Apr 02, 2013 8:35 pm
by kheaton
Not sure where you've tried for the carb parts but I've had good luck with MAP in Florida. There a few small shops that are good for finding the hard to find stuff:
Skinner's Motorcycles in Auburn,Al
British American in Atlanta
Ken
Posted: Thu Apr 04, 2013 2:15 pm
Thanks for the tip on other Shops.The Guy who had the Tranny Parts says he has one.I think the Distributor Idea is gonna get scrapped.I can't find an Ignition Box.I was gonna run an MSD Box, but they don't make one for 3 Cylinder.
Posted: Thu Apr 04, 2013 2:33 pm
by gearhead1951
Try 3 cylinder distributor off of a Geo , parts dont care where they are if they work
Posted: Thu Apr 04, 2013 9:45 pm
Thats what I have on there.The Distributor is a Magnetic Pickup.I need an Ignition Box in order for it to fire.I figured I would be able to run an MSD, but they dont make one for a 3 Cylinder.
Posted: Sun Apr 14, 2013 4:40 pm
The Light at the end of the Tunnel is getting brighter.The charging System in all wired up.Would've been able to say the same for the Ignition had I not dropped one of my fuckin Coils & broke it.I finished hooking up the Brake.The missing Parts for the Clutch are in.Need to figure out how to adjust it, then I can make up a Cable for that.Carb Parts are on there way.Carbs should be all set by mid Week.Just a few Parts left to PC.
Posted: Mon Dec 23, 2013 7:40 pm
Decided to play around with this one Today.Started hooking up the Clutch Pedal.Looks a little funky, but the Cable pulls through the bend real nice.
- Clutch Cable.JPG (150.58 KiB) Viewed 6701 times
....Also have a Question if Someone could answer...The Hole in the Pic where the Cable for the Slider in the Carb goes,there's supposed to be a rubber Grommet I guess Yuo'd call it.Well I've called several Places & noone has it.I'm concidering filling the Holes with Silicone.After a couple Days just work the Cable loose so it slides free.Any Thoughts on that?Should I try & cut Rubber to fit in the Holes?
- Grommet.JPG (123.77 KiB) Viewed 6701 times
Posted: Mon Dec 23, 2013 7:55 pm
bet u could find a Viton o ring in mc master carr
Posted: Mon Dec 23, 2013 10:30 pm
by Customize IT
+1
Posted: Tue Dec 24, 2013 12:14 am
I'll check them out...thanks
Posted: Tue Dec 24, 2013 3:07 pm
by Dusty-Dave
Posted: Tue Dec 24, 2013 9:56 pm
by Customize IT
+1 too that possible route too!
Posted: Wed Dec 25, 2013 12:25 am
by dirtbag
If you silicone it grease or oil the cable lightly it should free up no problem, a little short plastic tube with a bit of shrink wrap might look good and work
Posted: Fri Dec 27, 2013 6:26 pm
dirtbag wrote:If you silicone it grease or oil the cable lightly it should free up no problem
I think this is what I'll try 1st.
