69 BSA Rocket3... the Unholy Virgin
Re: 69 BSA Rocket3... the Unholy Virgin
Got the Clutch Pedal finished up Today.Just have to Anchor the Cable down.
Got the Clutch Cable anchored,but still not sure about adjusting it.I would think that when the Pedal gets pushed down I should be able to spin the drive Sprocket by hand which I can't.But I also made up the small Seals for the Carbs.Had to disassemble the Sliders to put them on.
You're gonna have a clutch PEDAL? Damn, how did I miss that? Good for you, I've ridden a panhead with a foot clutch, only problem I had was when I stopped at the cafe. I had never done that before, on anything, and when I was getting off, the back of my leg bumped the shifter into first gear.
All I could do to keep it from thumpin up the steps and thru the front door.
Cool ride tho, I think you'll really like it.
Yes I am Bob.Will be the 1st Time I ride a Foot Clutch.Probaly be a little learning Curve.I did finally get the Foot Controls Powder Coated just have to put them back on.
THRU THE FRONT DOOR!!!
NOW THAT IS AN ENTRANCE?
Finished up the wiring Today.Just have the Gas Tanks left to flat Clear.I have to redo the front Oil Tank.I hung it to low in the oven & burnt the Clear Coat...
Little something knocked off the List.Made me a rearview Mirror.Also was playing around trying to figure out my Grips.I'm gonna go with something like this.
Just sent out my last (hopefully) Order for some of the small things needed to finish her up.
I had to make a new Oil Tank.I liked the other alot more,but this one has way less fittings & it holds more.Should have the Oil Lines run by the Weekend.Then I think all I need to do after that is figure out this stupid Clutch & a Kick Stand.
Russ
- Tourist
- SELF INTRODUCTION: I an indepent biker, no offence to patch holders but I can't be bothered with all that tough guy stuff. I'm into old BMW boxers. Low budget builder. I like my family, my bike and not much else. My current project is an r100rs Beemer that was posted on the old chopperhandbook site under the title "Another BMW gets attacked with a hacksaw".
Every time I take a look at this build I see more details I like. Really want to see this one up and running.
Thanks Man...Shes winding down...primed the Engine with Oil the other Day.Soon as I seal the Tank, I just might try to kick it to Life.
canna wait for the you tube clip!!!..............love that fuel tap? nice touch!
Max...I got them through Mc-Master Carr.
My Sealer came in & I did the Tanks Today.Give them a Day to dry & button up some losse Ends.After that hope it runs.
