Page 2 of 3
Re: Irish's CBH Old School Chopper Project
Posted: Sat Jan 14, 2012 5:17 pm
by IRISH
Remove and throw away those conical springs.
- pull 'em out
- P9140014.JPG (29.63 KiB) Viewed 8321 times
The kit comes with snap rings that hold the new delrin plate and clutch housing in.
- the old stuff
- P9140015.JPG (42.37 KiB) Viewed 8321 times
Re-grease the rollers
- look in at your rollers - now is the time to install new grease. use the special moly stuff
- P9140016.JPG (31.64 KiB) Viewed 8321 times
Install the Ram Jett plate
- stick it in there!
- P9140017.JPG (35.1 KiB) Viewed 8321 times
Install the circlips (snap-rings)
- now these go in...use the pliers
- P9140019.JPG (42.13 KiB) Viewed 8321 times
Checking run-out of the housing
Posted: Sat Jan 14, 2012 5:47 pm
by IRISH
Re-install the discs and cover
- P9140023.JPG (37.3 KiB) Viewed 8321 times
Adjust the clutch.
- P9140025.JPG (42.44 KiB) Viewed 8321 times
You're done! Celebrate and go for a test ride! OK go for a test ride first...
- P9140011.JPG (60 KiB) Viewed 8321 times
The chain drive
- Drive...
- school yard bike pics 013small.jpg (101.25 KiB) Viewed 8321 times
The business side.
- The business side!
- P8130030small.JPG (100.99 KiB) Viewed 8321 times
Room for one more image so here you can see the bronze oil tank that I designed and my brother Grant built and engraved with my Skull Leaf Clover Irish Cycles logo. Thanks to pops David Irish who machined the vented cap and filler neck for the tank.
- Skull Leaf Clover Oil Bag by Grant Irish.JPG (73.63 KiB) Viewed 8321 times
Posted: Sat Jan 14, 2012 5:50 pm
by IRISH
OK I finally rounded up all of the photos that I have. I'll post them in order that they were taken which will show the different looks. The only real differences are the gas and oil tanks. Later I changed some other bits also. So here goes...
This is in my driveway while I was still tuning the carburetor and ignition and sorting the clutch and linkage for the clutch.
- This is June '06 with the bronze tank. I was engraved on top with my cyclhed logo, a skull with wings, no not HA! I need to find a picture. The tank is still around somewhere.
- Chopper june06.JPG (64.28 KiB) Viewed 8310 times
- The gas and oil tanks were made with silicon bronze sheet metal with brass caps and bungs. They had a bronze and green colored patina applied to them and then they were waxed. The gas tank looked cool, if a bit crude, but proved to be too heavy.
- Chopper 2 june06.JPG (57.78 KiB) Viewed 8310 times
I switched over to the original steel sporty frisco tank because the bronze tank was too heavy and broke the mounts off the frame! I also switched back and forth between the bronze and steel oil tanks when one would spring a leak and I'd have to weld it.
- On a ride in the North GA mountains Oct. '06
- craig_01L.jpg (129.48 KiB) Viewed 8310 times
- Oct. '06 Burnt Mountain Georgia
- craig_02L.jpg (144.96 KiB) Viewed 8310 times
Posted: Tue Jan 17, 2012 4:01 am
by IRISH
Posted: Tue Jan 17, 2012 4:35 am
by IRISH
Posted: Tue Jan 17, 2012 4:39 am
by IRISH
I moved from North GA to North CA in '08. The bike underwent a transformation soon thereafter....pictures coming soon. Stay tuned! Thanks for being patient and not posting here until its done! Craig
Posted: Tue Mar 06, 2012 1:13 am
by IRISH
Posted: Tue Mar 06, 2012 4:06 pm
by hose_dragger
Always loved watching your bike come together man. Great looking scooter!
Posted: Tue Apr 24, 2012 1:37 am
by IRISH
Posted: Tue Apr 24, 2012 2:00 am
by IRISH
Posted: Tue Apr 24, 2012 2:45 am
by IRISH
Posted: Tue Apr 24, 2012 2:56 am
by IRISH
Posted: Tue Apr 24, 2012 9:52 pm
looks much better with the lower tank
Posted: Tue May 22, 2012 2:39 am
by Kiwicaveman
Thanks for sharing your build. I followed it on the old board. Its one of the best build logs.................inspiring.
Cheers
Clive
Posted: Tue Nov 13, 2012 12:59 am
by IRISH
I thought I would finally finish adding the last pictures of my CBH Old School Chop. This is the final version of the motorcycle with the black paint, white flames and red striping.
